cmpski's Avatar
alternator wiring?
I have a Valeo alternator in my 69 911E and it seems to have an internal regulator. My regulator is on the relay panel. The alternator does not have the terminals identified. can you help?
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 01-23-2019, 12:34 PM
Under the radar
Trackrash's Avatar
Can you post a picture of your alternator? A '69 would have had a Motorola or Bosch alternator originally, with an external regulator. I believe it was the Carreras that used the internal regulator.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-23-2019, 02:01 PM
cmpski's Avatar
What I have here is a 2.4 Mod S built by Henry at Supertec. I've put the panel in the engine compartment that has a voltage regulator. The alternator has a voltage regulator in it (50amp) and a later non compatible wire harness. I'm somewht stumped at the moment.
Chris
www.reSeeWorks.com
Old 01-23-2019, 03:39 PM
Under the radar
Trackrash's Avatar
HBTDT there is a lot to consider. I put an SC motor in my '71, so I know it is a big job.
I don't think that alternator has a built in regulator. Can you post a picture of the fan housing showing the casting number.
What ignition and distributor are you using? Points? Can you post a picture of the ignition including the distributor harness.
That info will help us sort it out.
Gordon
Old 01-23-2019, 06:46 PM
The black wire is to be taped off.
The red goes to the 6 mm, large post,
The brown goes to the 5mm post 8mil nut
Blue wire goes to the 5 mm stud.
Voltage regulator on the wall is not used.
You need to check the alignment of the fan to the crank0pulley to insure you have the correct housing. The correct housing has a 19mm backspace that the Alternator bolts to
Bruce
Old 01-23-2019, 06:50 PM
Under the radar
Trackrash's Avatar
Bruce. Can you confirm that he has an internal regulated alternator? My GOOGle search lists it as a 55amp '70- '74.
Gordon
Old 01-23-2019, 07:32 PM
Yes Verlo, and the black box is the on board regulator I just don’t have any experience with the OBR for the pre 75 housing.
Bruce
Old 01-24-2019, 04:07 AM
When Porsche came out with the internal voltage regulators they issued a TSB on converting external regulators to internal ones. It's in this link.
Alternator w/ external regulator convert to internal regulator?
I know this is for later cars but the conversion is very similar.
Old 01-24-2019, 06:21 AM
cmpski's Avatar
Thanks guys.
www.reSeeWorks.com
Old 01-24-2019, 05:31 PM
