Broken wrist pin?
How common is this and what might cause it? How does oil get to these parts?
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Author of "101 Projects"
Never seen one broken - never heard of one breaking. I think the rod snaps and breaks before the wrist pin does. Or, the piston breaks at the point where the wrist pin is inserted.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Navin Johnson
Dont look!! scary pic...
Piston breaking at wrist pin
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Navin Johnson
Also, oil gets to the wrist pin via a squirter that is installed in the case. the squirter opens at 3 bar oil pressure I believe, and a stream of oil is sprayed on the underside of the piston..
the squirters werent installed to lube the wrist pin though... this was mainly accomplished by oil just being flung around the case... the squirterswere installed to lower piston crown temps... I notice in your sig you have a 71T... this could be on the bubble for having squirters... Some other engine gurus actuallly drill a hole in the connecting rod from the rod bearing to the wrist pin and pressure feed the wrist pin.... A guy who builds 1500HP engine told me that trick..
Motor is a rebuilt 3.2, and went back to the builder to remedy this problem.
I wondered if the rod was drilled, interesting idea. This motor does have a center drilled crank.
Navin Johnson
I just saw the'71T in your sig....
so if you have a 3.2 you have the squirters.. The fellow that told me about drilling through the rod to pressure feed the wrist pin builds drag motors...1500 hp etc..
Wanted to clarify...the wrist pin bushing cracked. It was knocking pretty loudly around 3K RPM.
The shop that built it tore it all the way down, redid the rods and put it back together. All is well so far.
-Wayne
Nope...
