rw7810's Avatar
Carrera oil pump in a 2.2 issue
I put a carrera oil pump with the built on scavenger screen in a 2.2 ltr. When you do that, the sump plate you have to use is a dish shape with no oil drain plug. This necesitates loosening or taking the sump plate off to change oil. Has anyone been there?? Any recommendations on a better solution??
Robert Williams
70' 911T
Old 05-19-2004, 09:36 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We've got what you need
Supertec makes a sump plate conversion for just such an engine. $50.00 and your old conversion sump plate. If this seems too expensive you can machine a bung and braze it into your sump plate and screw in your a drain plug from a 3.2.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-19-2004, 01:42 PM
rw7810's Avatar
Excellent - that's it. thanks for the info!
Robert Williams
70' 911T
Old 05-19-2004, 01:54 PM
