Alan.UK's Avatar
3.0 webers what size venturis
What size venturis have people used with a standard 3.0 sc motor with webers. Will 32mm be ok ?
Alan
Old 05-19-2004, 11:47 AM
No Expert
jgparker's Avatar
I think 32mm will be OK and the drivability will be good, but for peek HP bigger might be the way to go. I'm still learning too...
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-19-2004, 02:49 PM
Alan:
32mm ones are too small for a 3.0 litre engine.
Use 34mm or 36mm ones depending on cams.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-19-2004, 11:48 PM
Author of "101 Projects"
Wayne 962's Avatar
Right, the stock cams are so mild that 32s will work semi-okay, but as soon as you go to something hotter, you need to rejet to something bigger...
-Wayne
Old 05-20-2004, 12:29 AM
Alan.UK's Avatar
Thanks guys,
I think with the stock 3.0 with webers I will stay with the 32s. I don't suppose you can suggest what jets and emulsion tubes I should use in the webers (in the standard 3.0 motor).
Thanks in advance
Always learning
Old 05-21-2004, 03:20 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If you have a late small port 3.0 80-83 the 32 mm venturis will work to about 5900 rpm. If you have a big port engine 78-79 the 32 venturis will tend to be small though out the range. A good place to start is: 155 mains, 180 airs, 60 idle, f3 emulsion tubes.
Good luck
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-21-2004, 07:17 AM
Alan.UK's Avatar
Thanks Henry
I will try that set up in the 80-83 204 bhp (euro) SC motor that I am doing for a friend. In my own 3.0 conversion that I doing at the same time I will use 34mm venturis maybe even 35 as I have a large port 78-79 3.0 motor but mine is having S cams and 98mm P&P. Do you suggest I start with the same jets for my car? I only ask as I am about to order all the new jets and tubes.
Alan.UK
Always learning
Old 05-21-2004, 07:32 AM
Alan.UK
The euro engine really needs the bigger venturis. It is a simple job the bore the venturis to the size you need if larger ones are not available. Even a small hobby lathe will work.
The jetting on either will work for a starting point. It seems that jetting is mystical and there are no set rules went it come to final jetting of carbs in general.
Good luck
Henry Schmidt
Ph: 760-728-3062
Old 05-21-2004, 08:11 AM
Alan.UK's Avatar
Thanks Henry,
I think I will get them bored out to 34mm and use the jet set up you suggest. I will let you know how I get on.
Alan.UK
Always learning
Old 05-21-2004, 08:16 AM
