echrisconnor's Avatar
Cam Nut Removal
Any tips on doing this solo when you don't have an impact wrench and you're doing it with two breaker bars? I want to do this over the weekend, but won't have anyone to help out.
Any thoughts?
'76 911 Carrera 3.0
Old 05-21-2004, 08:11 AM
Irrationally exuberant
ChrisBennet's Avatar
Re: Cam Nut Removal
Any thoughts?
Sounds to me like you need to make more friends.
The little 6mm studs that hold the cam box covers on are really easy to break off if you aren't careful. You could get creative with a breaker bar wedged against the floor but I think you are asking for trouble.
Have you considered ordering a pizza delivered and then paying the delivery guy/girl to hold the other breaker bar (for an extra tip)?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-21-2004, 08:32 AM
camgrinder's Avatar
Cam Nut removal options???
look here
John Dougherty
Dougherty Racing Cams
Old 05-21-2004, 08:48 AM
dtw dtw is offline
GAFB
Just lock the flywheel and use one bar...?
Otherwise, I time cams alone no problem, using two wrenches...it requires finesse, but I'm able to torque while holding both wrenches. I use a big PVC cheater over the wrench on the cam, it make it easier to hold it steady as I torque the nut. Just takes a little practice. Those who know me will argue this is because I am a grizzly bear, but I showed Tim how to do it (he ain't no grizzly bear) and he can do it too.
Several BMWs
Old 05-21-2004, 08:58 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
yep took me a try or two but I got the hang of it and I'm 6'1 and 165.. not a big guy at all.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-21-2004, 09:15 AM
No Expert
jgparker's Avatar
It helps if your breaker bars do not have much flex, and if they do not have a swivel head. The flex makes it hard to break the nut without a lot of movement, and the swivel makes it hard to keep the crow's foot on the nut. I do it solo, but you have to have the right tools.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-21-2004, 01:34 PM
I have two swively breakers. One's 27" one's 15" and I've got plenty of pipe for extensions. I'm recruiting a buddy to assist. Do folks generally recommend some heat first? Maybe hammer the bar once or twice before starting?
'76 911 Carrera 3.0
Old 05-21-2004, 01:38 PM
i took one apart recently that had big ugly chisel gouges going in both directions, so someone obviously found another way to do it. get the right tools.
206 637 4071
Old 05-21-2004, 07:01 PM
dtw dtw is offline
GAFB
Actually Wayne, I find just a big 46mm socket to be much easier to use on disassembly, much better engagement than the crow's foot. Breaker bar and locked flywheel or air impact wrench...either way works...
Several BMWs
Old 05-23-2004, 03:41 PM
Author of "101 Projects"
Wayne 962's Avatar
Air impact okay - maybe locking the flywheel, although you're guaranteed to toast your chains. Either way, you still need the proper tools to reattach and torque the nut, so why not use them to remove it?
-Wayne
Old 05-23-2004, 03:50 PM
Man, was that easy. I recruited a buddy, and I had told him, we just have this one thing to do, and that hopefully we'd get it done in about an hour... Had both off in under one minute.
The night before I had applied some heat and PB blaster, then heat and some beeswax. They came off like butter. Having the breaker bar with the cam holding fixture secured against one of the engine mounting studs was the key too. My buddy just made sure it stayed in place while I turned the nut (using the proper cam holding tool, mind you). No problems.
Thanks all.
'76 911 Carrera 3.0
Old 05-24-2004, 07:20 AM
