Ho Hum 74's Avatar
Wayne or other gurus: Help me with my timing
Looking at the Engine Rebuild book it says for the Euro 2.7 RS engine the timing is 0 degrees at idle.
My engine is similar configuration being 2.7 9.8:1 JE Pistons and Modified S Cams by Elgin. I have timed it to 0Degrees and it seems happy. Is this correct?
Tristan
Old 05-27-2004, 04:14 PM
Tristan,
That spec is only correct if you have an RS spec distributor. If you are using the original 2.7 distributor then you should set it to the spec for that original engine. All the cars specify a window of 30 to 35 degrees advance at 6k rpm. Most 2.4/2.7 engines are set to 5 degrees ATDC with the vacuum retard connected. This will give the 30-35 degrees at 6k. If you measure at 6k be sure to disconnect the vacuum retard. If you set one of these to zero you may have too much advance.
-Andy
Old 05-27-2004, 08:19 PM
Ho Hum 74's Avatar
Thanks Wayne and Andy.
I believe I'm using the original 2.7 distributor with the vacuum hose.
I'll set it to 5 ATDC. That's the second mark after the Z mark right?
Tristan
Old 05-28-2004, 05:46 AM
So what is an ideal initial advance for a hot-cammed motor? Say you had an electromotive setup where the initial advance is free. I have been told 10-12 deg is ideal, I have found that to be too much.
73 914-6 SCCA EP Race Car
71 911T - (In Progress)
67 911 - Not long for this world
Old 05-28-2004, 05:54 AM
No Expert
jgparker's Avatar
I thought the critcal ignition timing measurement was at 6K, not idle, and should be in the 30 to 32 degree BTDC for a hot-cam single plug engine. Could some of the pros jump in on this question?
Thanks,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-28-2004, 08:22 AM
Ho Hum 74's Avatar
What mark on the pulley do i need to align it with at 6k?
Tristan
Old 05-28-2004, 08:35 AM
No Expert
jgparker's Avatar
On most pulleys, there is a 30 and 35 degree BTDC marks. (See pic). BA once told me "start on 30 and see how it runs"
Good luck,
JP
Old 05-28-2004, 02:35 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Total Advance
When working with performance engines, it would seem reasonable to set the engine at TDC when you first start it. Once the engine is warm, run it up the where you're certain total advance will be achieved . On a 911 6000 rpm is a good number. set the engine between 30 and 35 degrees depending on engine specs and fuel availability. Allow the engine to idle down. If the engine returns to idle you win. If not adjust your idle adjustment as necessary. If it won't return to idle you have two choices. Replace/Recurve the distributor or give up performance by retarding the timing.
You Choose
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-28-2004, 04:17 PM
Author of "101 Projects"
Wayne 962's Avatar
Thanks,
JP
Yes, this is a critical mesurement - you want to make sure that your engine doesn't exceed the total advance at these higher RPMs, otherwise you may experience detonation and engine damage.
The lower end is also important for maximizing your power off of the line. The good thing about programmable ignition systems is that these two measurements are independent of each other. On a distributor-based system, the advance on the low and high end are related via the distributor weights.
-Wayne
Old 05-28-2004, 04:24 PM
my factory Calif 2.7 dizzy used a vac advance. I set to zero and disconnected the vac permanently. It runs cooler and sharper at low and mid rpms w/CIS. it's also doable for carbs because you'll have more lower rpm advance .. many other 2.7s in the US and Canada had the same dizzy vac hose plugged at new delivery. I now run the 2.7RS dizzy.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-01-2004, 09:53 PM
By way of reference, the early S distributors produce about 25º of advance via the centrifugal weights. The initial timing specs are 5º BTDC for a total of about 30-32º of total spark advance. The S timing curve provides more spark advance at lower rpm for added torque (something the 2 liter S needed). Like Wayne and others suggest, be aware of excessive spark advance at max rpm.
Since all engines are slightly different, the best method is to perform a spark test on a chassis dyno. That way, you will know the best spark advance throughout the rpm range (with some headroom), then recurve the distributor or ECU accordingly.
Sherwood
PS: Early S distributors don't use a vacuum unit.
Old 06-02-2004, 08:01 PM
Slumlord
Porsche_monkey's Avatar
So you rev your engine to 6000 rpm to check the 30-35 degrees?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-03-2004, 04:41 AM
Yes. It's noisy, but you don't hold it at that speed very long.
Sherwood
Old 06-03-2004, 09:56 AM
