cosmo's Avatar
MFI Fuel line leak
Engine is finally in and cranking but #1 injector continues to leak.
I've tried retighting and even pulled it apart and inspected it several times, both line end and injector look fine but!!!!!!!!!!! It still leaks. Any ideas?? 2.2 MFI
04 996 TT
71 911E
73 911S Targa
61 356 Coupe
69 XKE OTS
68 XKE Coupe
65 Healey BH8
Old 06-06-2004, 03:35 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Look for a very small crack. The hard lines vibrate and crack. You can use a fuel injection pressure tester to see where your line is leaking. I have never seen an injector leak so if the seat on the injector is not damaged your problem is the line. We may have a replaement in stock. Call and I'll check.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-07-2004, 07:31 AM
