Hbrand
Smoking engine
My 2.4 911S engine smokes bad.
Not at start up but when warm. Compression is 170 on all cylinders. What causes that? Valve seals? thanks, harold
Cheers 1982 Porsche 911SC Euro 1969 Mercedes 280SL 1956 Austin Healey 3x |
Air Medal or two
Hmmm wide open anser....evrything from oil leaks to the out side to oil leaks in the inside.....oil on the exhaust ?? worn rings and yes worn guides
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Smoke
It helps to know the color of the smoke...
White=Oil Black=Fuel |
Hbrand
Blue smoke, after about 3 minutes of engine running, worse when I rev the engine. No outside leaks.
Will check the intake valve seal and guide. thanks
Air Medal or two
probably guides....
Crusty Conservative
What oil are you using & weight? What is the warm tank level reading?
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Out the tail pipe? At least a top end rebuild.
Otherwise if it is something like a line you with help of this forum can fix it. Good luck.
Bernard |
