case stud torque specs
Does anyone have torque specifications for installing case studs (not head studs) for the inner studs on both halves of the case?
My machinist pulled some of the studs to do the machine work, forgot to reinstall them, so I have to reinstall them. Also, do I need to loctite them? Car is a 3.3L Turbo - 1983. Thanks, Brian briankeithsmith@ctc.net
Brian Keith Smith |
Irrationally exuberant
You just thread them into the case. Possibly just by hand. You absolutely don't even want to torque them into the case. The only way they'll get any torque on them is if they bottom out. If you bottom them out and keep twisting you will damage the case threads.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Author of "101 Projects"
Use Loctite, and install them to the correct height...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne, but none of my materials include the specs on that type of stuff, at least not that I have seen yet.
So I have no idea what the heights should be. Anyone out there have a listing of the inner stud heights? Thanks, Brian
Brian Keith Smith |
No Expert
135mm from the top of the case to the cylinder base deck. If you get this wrong, you either wont have enought thread, or the stud will push out your allen socket on torquing. It is not even finger tight on many engines, sometimes they even have a wobble. Use Locktite 271 (Red).
Good luck JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
I'll be done measuring a case today or tomorrow. When I'm done I can measure the length (of the exposed part) of the internal studs for you. Let me know if you need me to. Porsche specifies their stud lengths as the exposed part i.e. a stud that measures say 47mm end to end might be listed as 35mm by Porsche. This always struck me as odd but maybe it can work to your advantage. Perhaps you can look up the studs on a Porsche parts diagram (PET) and get the exposed length that way? -Chris
Thanks Chris.
I appreciate your assistance. Brian
Brian Keith Smith |
No Expert
Woops, I missed that you were talking about the case perimeter studs. The parts book lists these as M8 by 32MM, quantity 12.
As Chris mentioned, this refers to 32MM protruding from the mating surface, not the full lenght of the stud. A source of confusion, but helpful when installing them. Good luck, JP
Hi Brian,
It didn't occur to me to note which case style you have. This is (obviously) a later case (late '83-89). Hope this helps. Pelican's BBS reduces pictures some. In the picture below, the green captioned stud in the upper left reads "54mm". ![]() If not specified, the studs lengths are 34-35mm long. -Chris
THANKS A TON MAN!!!
That helps out alot! You are the man! Brian
Brian Keith Smith |
You're welcome!
-Chris
Brian,
Um, you could have called for that one
Stephen 94 3.6Turbo 6-speed AWD |
Sorry dude... Didn't want to bother you.
Thanks again guys! Brian
Brian Keith Smith |
Chris:
Thanks to your help, I got the case sealed up today with the help of my trusty friend Chad! Case is sealed and pistons and cylinders are installed. Brian Rebuild Pics
Brian Keith Smith |
Way to Brian. Now don't forget the cooling tin before you put the heads on. I've done that a few times.
![]() -Chris
