I can't answer either question, but turbo motors are a chunk heavier than the early motors I usually see this mod on. While you might be fine, aren't there "safer" places to save weight on a 930?
I'm shedding a ton of weight off the engine but it gets addictive (how much is that lightweight starter again?:) ) Besides the bar all the way at the back of the car.
I haven't weighed the stock FI system, but I know it's a PITA lifting the box of old parts up on the shelf. Then there's the stock 930 clutch pressure plate, what were they thinking? I've got FEA software at work, but I'm getting lazy. I'll do some searching and maybe run a model myself. |
I had a problem when i first lightened the mount I went too LG on the holes. it cracked in one area, my fab guy welded in a small gusset and it has been reliable since. he also drilled lg holes in the mount that bolts to the case
2pac... It's two stage paint system where a hardener is added to paint so that it "chemically dries" rather than just "air dry". Kind of like fibre glass resin.
It's brilliant to work with and has a great finish off the gun, but it's really toxic and you need to use a respirator. There a quite a few threads about it under "painting". Minkoff, have been saving your pictures for a while now ;) |
| All times are GMT -8. The time now is 11:56 AM. |
