Engine update pic
Getting close now. Just waiting for a few parts from Pelican to arrive so I can set my timing and check valve to piston clearance.
http://forums.pelicanparts.com/uploa...1087192237.jpg I can't decide on all red, or to do the valve covers in black with the red shroud ( I love 2pac paint!) And yes I know it's not a "prescribed yoke" Cheers |
I really like the all-red look--MHO. What kind of engine is it?
Yeah, I'm thinking all red now...
It's a 2.7 RS spec on webers... |
Looks nice!
I used that same universal "yoke"- it worked fine.
Jeff |
Red, black, silver, some sort of combo, it just doesn't matter. This is your job and it should suit your taste. I think what you have done looks great. You choose the valve covers.
Here is one we did. As for the yoke, if it works, use it. I don't think I would trust that yoke with a complete 930 engine (too heavy) There is a company that makes a Porsche adapter for this type of yoke. We bought one and it works well.http://forums.pelicanparts.com/uploa...1087232159.jpg http://forums.pelicanparts.com/uploa...1087232191.jpg |
Thanks Henry... now silver is looking good!
I found one of those adapters on the net, but I'm comfortable with the current yoke for an earlier engine. Cheers |
Here is another one we did. http://forums.pelicanparts.com/uploa...1087335356.jpg Note the sheet metal and machined valve covers on this one. For those of who missed it, this one's for a 914-6 |
That one looks excellent! That's probably very close to what I'll do I think.
Thanks |
Here's the way mine turned out 2000 miles ago.
http://forums.pelicanparts.com/uploa...1087356127.jpg |
Love the fan! Polished and coated?
Wow! Those engines are beautiful. How in the world do you guys plan to keep them clean?
I'm just finishing my rebuild.
So I wanted to add my motor to the thread. RED/BLACK/SILVER http://forums.pelicanparts.com/uploa...1087374270.jpg |
I like the red, that's probably the color I'll use. What's 2pac paint?
I explained in a thread a while back that I left it uncoated and sitting waiting while I asembled the rest of the engine. It oxidized in just a few weeks. Not bad, but enough to haze the mirror finish with chalky oxidation. |
It's leak free topside. I have one transmission leak from the shifter rod seal that must have been a bad new part. It leaks a drop of Swepco every other run. The engine is dry below. Lee 78SC |
I was waitin' for that.
I've seen some engines with the mustashe bar drilled out like the one in this thread and the one on Wayne's book. Has anyone seen a failure with this mod? Has anyone seen it on a turbo motor?
| All times are GMT -8. The time now is 01:42 PM. |
