turbo dave's Avatar
2.7 CIS system on a 3.0
Guys, would this work? Are there significant differences between the 2.7 CIS systems and the 3.0 CIS? What about different years of 3.0- the ignition & ports were changed after '79, right?
Thanks,
David Schultz
1973 911T 2.7
Old 06-24-2004, 09:11 PM
Zombie
Atleast the diameter of the intake runners are different. I think you shouldn be very careful if you use the 2.7 CIS in 3.0 engine. It could be good idea compare all the parts numbers and see which are the same and which are not the same parts. Sorry I can not help more.....
Timo
914-6
Old 06-28-2004, 03:14 AM
