Jeff, I hear you, but remember that rod bolts were installed for years using a beam-style torque wrench, lubricant and a guess. Then came the angle torque method, a more sophisticated guess. So suppose you're ARP, you're thinking, "anything we can do to enhance the ability to get a repeatable stretch will lower the failure rate of our bolts, enhancing customer satisfaction AND we get to sell a $10 chinese-made dial indicator and an anodized aluminum frame for $150!"
If I'm going to the trouble to engineer my own gage, I'm going to try to avoid some of the known pitfalls of the ones on the market. Such as, making the frame out of aluminum, which bends and expands a lot when heated. It's all theoretical of course. . .
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Makes sense, can't really argue with that!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Navin Johnson
I wish I had pictures of the measuring devices we used to tighten the cable bands on some of the big suspension bridges (GW, Verrazano, Williamsburg, Throgs Neck, Whitestone)
In reality they are just larger versions of the bolt stretch gauges used to verify rod bolt elongation.. If I may just step in and smack you guys upside the head!! I think you are making mountains out of mole hills...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Tim, I will drive across the GWB in complete confidence knowing that it was you who tightened the cable bands.
![]() Of COURSE it's overkill, that's what makes it a fun exercise. Then again, trying to design a tool that's cheaper and more accurate than the commercial alternatives is the essence of the Pelican DIY spirit.
