-   -   964 engine rebuild 11.3:1 compression (http://forums.pelicanparts.com/911-engine-rebuilding-forum/168555-964-engine-rebuild-11-3-1-compression.html)
john_colasante 06-29-2004 09:28 AM
Originally posted by ChrisBennet
IMO, I don't think any racing body is going to accept a motor with 9 points higher compression (than a truly stock motor) as "stock".
-Chris
I would think if you built the motor to the spec you are legal.
ChrisBennet 06-29-2004 10:09 AM
Yes, that true but you have to comply with all the specs - not just the compression ratio one.
In this case we are talking about ignoring all the other specs to get a desired compression ratio. There is a spec for the cylinder height for example. You can't just lop off whatever you want.
I don't know if PCA stock rules allow machining of any components short of resurfacing the heads.
I don't know how the factory arrives at their compression ratio (does anyone?) but they are obviously using a different method.
-Chris
john_colasante 06-29-2004 10:44 AM
PCA stock rules say machining for balance purposes only.
Still, I think 11.3:1 MUST be achieved for maximum "stock" performance. Would race gas be required? I guess so.
ChrisBennet 06-29-2004 11:00 AM
Maybe they are already 11.3:1 - using the Porsche compression measuring method.
If there is any question, one could simply ask the PCA Race rules guy. I think we both know what he would say. ;)
-Chris
