hkspwrsche's Avatar
See Pic- odd spec for cam towers/rocker?
Is anyone aware of a spec for the cam tower (where rockershaft sits) to the side edge of the rocker arm?
In case it's out of spec it can rock or hop during it's rotational motion. Trying to figure out if I should eye ball it or if it's a tighter spec that I wouldnt see. I havent seen the spec listed.
Harold
Old 06-22-2004, 12:03 PM
hkspwrsche's Avatar
The car is a 1979 SC with a 3.0. This is the clearance spec on either side of the rocker arm to the cam tower.
Harold.
Harold
Old 06-25-2004, 07:49 AM
hkspwrsche's Avatar
hope this helps
Old 06-25-2004, 10:56 AM
hkspwrsche's Avatar
The distance between the "virtual" cam tower and the side of the rocker arm as shown in the pic.
Harold
Harold
Old 06-28-2004, 08:17 AM
Forced Induction Junkie
WERK I's Avatar
C'mon guys, someone must have the spec for this. I'm very curious too. There must be a spec for the thrust clearance between the rocker and cam tower rocker arm support.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-29-2004, 08:57 AM
ArtechnikA's Avatar
Send a message via AIM to ArtechnikA
you didn't specify a year, so i can't comment on engines outside the years i have access to information for...
but the '69->'71 spec book says rocker arm end play from 0,100mm to 0,350mm; wear limit 0,50mm
(p32)
[ http://www.ArtechnikA.com ]
Old 07-02-2004, 06:21 AM
hkspwrsche's Avatar
I wonder if they mean side or if that is on each end instead of each side. Looks close to the adjustment spec for valve adj.
Harold
Harold
Old 07-02-2004, 01:16 PM
