svonkampen's Avatar
Any 2.0 owners out there who built a Short-Stroke 3.2L ?
Hi,
I asked Wayne what would be his pick for rebuilding my 1968L engine, and he suggested the "Short-Stroke 3.2L" engine mentioned in his book on 911 Engine Rebuilds......
I like my 901 tranny and he said it would bolt right on.........
Anyway, anyone out there with an early 911 featuring this configuration?
SvK
SvK
1996 993
1968 911L 3.0 Carb'd.....(sold)
"I don't even know enough to know that I don't know."
Old 06-27-2004, 08:06 PM
Licensed User
Shuie's Avatar
Ive got one, but its on a pallet right now. Ive never heard anyone say anyhting bad about the engine. Your car is smaller and lighter than most so it should be a real hoot to drive when done
Mine is setup with Webers. I have not confirmed a compression ratio, which pistons it was built with, or the cam. Im going to send it to Henry at Supertec to be refreshed.
Unless you build it on a early turbo casewith a 2.7 6 bolt crank you will probably need an adapter to hook it up to your 901. I think you can get the adpater from Patrick MotorSports. The 914 gang will know for sure.
Good luck!
Old 06-27-2004, 08:18 PM
svonkampen's Avatar
Thanx Shuie......
Ok......where do I buy all the parts......
Pistons
Heads
Cams
SvK
SvK
1996 993
Old 06-27-2004, 08:25 PM
Licensed User
Shuie's Avatar
I think Pelican sells everything you will need. Read Wayne's book a few times. Read Bruce Anderson's book a few times as well. They both document this engine.
Start with a rebuildable 3.0 core. Preferably a '78 or '79 SC motor since it has the bigger ports on the heads.
There are several different sets of 98mm P&Cs. Call (Andial) someone who really knows exactly which set of pistons and cylinders you need. RSR, and Max-Moritz P&Cs are not the same thing. They come in different compression ratios as well but try to keep everything under 10:1 unless you have budgetted for twin ignition.
What induction? CIS will probably be the easiest since it will come with the core motor. If you want to go to carbs, a decent set of Webers will cost you $1k. PMO's will cost you $3k. Budget $3k-5k and some more money for extra machine work on your heads if you want MFI. Just make sure you have all of the details hammered out before you start ordering P&Cs or any other parts.
Run a 20/21 or a 964 cam if you keep the CIS induction. Run something like a GE80 with carbs or MFI.
How is your oil cooling? If you dont have a good external cooler, budget for one.
Good luck!
Old 06-27-2004, 08:40 PM
svonkampen's Avatar
Shuie,
Excuse my ignorance......
But with this engine my 1968 911L would do 0 to 60 in what?
I know weight is a big factor (my seats are Recaro Sport Seats) just approximately.....
SvK
SvK
1996 993
Old 06-27-2004, 09:23 PM
beepbeep's Avatar
Sell your engine and transmission and buy 3.2 Carrera drivetrain to slot in. It's much less fuss and cheaper too. 901 tranny is too weak and must go anyway.
Thank you for your time,
Old 06-28-2004, 02:24 AM
Super Moderator
cstreit's Avatar
The early turbo case, or 76-77 3.0L carrera is the best place to start. I've got one in the shop. Very reliable and revs TO THE MOON.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-01-2004, 04:52 PM
Navin Johnson
TimT's Avatar
I have a 3.2 bolted to a 914 (901) tranny....bolts right up... build the most engine you can afford to..
'69 911 GT-5
'75 914 GT-3
and others
Old 07-01-2004, 06:02 PM
Svon- do a search on my fellow countryman CamB's 69T-to-fire-breathing short stroke 3.2 build for some inspiration. He did it on a narrow body too, so all due respect.
He's been quiet lately (cos I think he's too scared to drive it )
A search will reveal all his worries and answers.
'72 911 T/E Silver Targa
Old 07-02-2004, 01:02 AM
svonkampen's Avatar
Thanx Matt,
SvK
SvK
1996 993
Old 07-02-2004, 02:11 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally posted by svonkampen
Thanx Shuie......
Pistons
Heads
Cams
SvK
Along with Pelican Parts we have everything you need. Try them 1st and let me know if PP doesn't have what you are looking for.
We have a great selection of used air cooled 911 based engine and transmission parts.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-03-2004, 10:27 AM
350HP930's Avatar
Damn Henry. And I thought Dave White had a big stash of air cooled porsche stuff.
Old 07-03-2004, 06:40 PM
chuckw951's Avatar
I think this debateable depending on the application. If you go easy on first and don't run too much torque the 901 works fine, IMHO.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 07-04-2004, 07:54 AM
No Expert
jgparker's Avatar
I second that. 901 is very robust, except for first gear. The shift patern is better too.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 07-04-2004, 10:22 AM
beepbeep's Avatar
I just know that 901 has lower torque rating than 915 which itself twists it's case and wears down quickly when subjected to 930 torque.
Wevo Hayden can fill on this.
Old 07-04-2004, 03:39 PM
