Is this piston OK to use (Picture of the nick)
This piston is perfect in every way but once it was cleaned you could see the nick in the picture. Not sure what happened but it is more like a chip. No damage to cylinder and all looks but I wanted a second opinion.
82 911SC
74 MGB
97 Land Rover Discovery
Old 09-15-2008, 08:53 AM
BURN-BROS's Avatar
It,s fine. Take a jewelers file and take down any high spots/ sharp edges that may have occured.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 09-15-2008, 05:48 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Aaron, you brutal bastard! It looks like you'll use anything. I wouldn't let you near anything I own.
Next thing you know, you'll be welding a bolt in a wrist pin.
Perfection is always the goal
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-16-2008, 08:18 AM
BURN-BROS's Avatar
You Sir, need to step away from all power tools and any innocent hydraulic presses.
Burnham Performance
Old 09-16-2008, 05:38 PM
I would rather be driving
jpnovak's Avatar
I sense a few inside jokes between Henry and Aaron...
Thank you for the comic relief.
Old 09-16-2008, 07:38 PM
