Mick_D's Avatar
12 year old threads never die, they just get spicier.
Old 03-20-2016, 09:30 AM
Puny Bird
Mark Henry's Avatar
Dang....some anthropologist dug up an ancient thread and I fell for it
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-20-2016, 10:00 AM
Originally Posted by Henry Schmidt View Post
Gilroy was the garlic capital of California, the USA and maybe the world but almost 60% of the garlic sold in the US is grown in China.
Henry,
Have you tried 'Rose de Lautrec' Garlic from France or Aglio Rosso di Sulmona from Italy? I always used to buy these types when I travelled to Europe for work.
The bleached rubbish from China is poor and if Monsanto win the battle most garlic will be GM type.
Boat tailing has always interested me but I have never seen any test results.
In theory at least fluids moving in a streamlined manner don't like square corners and depending on their density and viscosity the turbulence generated can be significant.
The worst impact may be on oil temperature which could be difficult to translate into a parasitic loss that could be measured reliably on a dyno.
I would think that the 10% claimed would be quite easy to measure on a repeatable basis as we certainly achieved around 0.25% on a high speed water brake with in-line torque measurement.
Modern 4 - Quadrant 'motoring' dyno's of the type produced by AVL should manage this accuracy quite easily (https://www.avl.com/-/avl-dynospir-1) and even older designs with load cells and trunnion bearings should manage 1%.
I must say that I think 10% is very optimistic as the effect of this much windage on oil temperature would be huge and easily observable.
Old 03-20-2016, 10:27 AM
Air Medal or two
afterburn 549's Avatar
I bet Smoky Yunick would have boat tailed .
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 03-22-2016, 02:28 PM
AlfonsoR's Avatar
OK, I'll bite..... Chris, where can i get this fancy garlic? I love the stuff.
"Simplicity is supreme excellence" - James Watt
Old 03-24-2016, 08:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by chris_seven View Post
Henry,
I would be interested in seeing your actual data on oil temp changes directly related to boat tailing a 911 case.
I wonder why Porsche factory in all their wisdom missed this aspect of case design.
I always thought that if their was any benefit to shaping the main webs that Porsche would have simply cast the case with a slight taper or curvature of the web instead of the flat surface we see in every engine. The early engines (sand cast aluminum ) had a slightly round main web but in later designs Porsche moved away from that feature.
Live and learn..
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-25-2016, 09:23 AM
