E cam value?
What is a nice set of E cams worth?
They are coming out of my car on Thursday and will be for sale. I pulled the rockers this weekend and all of the lobes look perfect. Paul
My ignition is retarded. |
regrind E cams on Ebay 295.00 . Motor miser 299.00 Ex
What are you going to put in, paul?
Andy |
I would rather be driving
What is going in the 3.5? Mo' Powah!
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I am putting in a Webcam racing cam for big bore motors. The guy installing the cams has a dyno so i should have results in a week or so. It should be quite an improvement.
PLT
Try not, Do or Do not
Be careful, "E" pistons have very shallow valve pockets. If the cam you choose is too aggressive the valve to piston clearance will be inadequate or non existent.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-24-2004 at 09:24 PM.. |
The most popular cam swap for the 911 E is the Solex cam. With the tight lobe centers (97) and added duration, you have increased lift at overlap. Lately I have been grinding the solex cam on a 102 lobe center. This is the same L/C as the 911 E and helps with the valve to piston problem. It also give the engine a wider power band.
John Dougherty Dougherty Racing Cams |
Paul's car has a MFI injected 3.5, no shallow E pistons there.
Paul, WHo's doing the work? David Brown?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Close.. His has 69S stacks, K&N's with rainguards and an electromotive twinplug ignition.
That's a really nice setup, but if that's a 3.5 liter motor, then why is it singled plugged? I've seen that picture before and it always confuses me. It looks like those are plain-jane MFI throttle bodies, but without the linkages or any aparatus to actuate the throttle plates. How does that work?
The picture was taken before the engine was finished. it uses a modified stock cross bar and linkage.
Twin plugging is over rated. This engine made 369 rwhp. I've read that any engine over 3.4 should have twin plugs. Well, perhaps that statement is in error. The money it cost to twin plug was better spent else where. When we build race engine, twin plugging is one of the last things we do.
Licensed User
Henry, is the twin plug issue over rated because this is a race engine setup to run on high octane leaded race fuel or can the big bore high compression engines run on pump gas without twin ignition and fears of detonation?
Related Question: How much, if any at all, does running a MSD with a bigger plug gap help to avoid detonation or the need for twin ignition? TIA |
Author of "101 Projects"
If you do encounter a problem, simply enlarge the pockets in the pistons (no less than 5mm of material from the back to front of the piston). -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
