Early oil pump with late pressure relief pistons
I just pulled a motor apart that had low oil pressure and had this combination. Would this contribute to a low pressure problem. Also, I have found quite a bit of metal shavings in the oil screen but all the bearings are still intact. Can I take the oil pump apart to check the internals?
73 914-6 SCCA EP Race Car 71 911T - (In Progress) 67 911 - Not long for this world |
Air Medal or two
well....you dont say which eng.- 2.7 with oil mod HAS to have the newer relive pistons in the right holes- is that your question??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Navin Johnson
Did you check the pressure with a mechanical gauge? or was the low pressure just indicated on the dash gauge? My dash gauge reads low, between 0-5psi hot.. I checked with a mechanical gauge and the real oil pressure is 15psi at idle, hot engine..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Try not, Do or Do not
Re: Early oil pump with late pressure relief pistons
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
