Hi gang,
It's nearing 1,000km's since my engine rebuild and I was wondering what's typically done at this 1K service? I have stayed under 4Krpms religiously and not driven her under load at all. Anyway, is it just an oil flush, new oil filter, check for leaks and check valve clearances, or more involved than that? How much time does it typically take to check valve clearances? Advice greatly appreciated.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Friend of Warren
You have covered what needs to be done. If you are checking the valves yourself and it is your first time, give yourself 3-4 hours. Once you do all of that, you can start running the engine up to redline.
Kurt V No more Porsches, but a revolving number of motorcycles. |
OK thanks for clarifying. I won't run a synthetic oil just yet. I might go with a light-weight dino for a further 4,000km's and then run synthetic.
I'd also double check the head stud torques while the valve covers are off. Don't loosen and re-tighten, just check and tighten as necessary.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I have had ARP head-studs fitted. Could they loosen?
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks guys! BTW, what should the torque settings be for the head studs on a turbocharged Carrera engine?
Any recommendations for a really good lightweight Dino oil?
