magic930's Avatar
87 930 wiring help
I do not have the factory wiring diagrams and am relying on a Bentley Carrera manual for wiring which does not seem to have the wires I am looking for...
From the middle pin of the starter there is a white with blue flecks wire... what connects to the other end of this wire?
From the alternator there are 2 thin brown ground wires that are both attached to the 10'oclock position/which is the same as the black ground strap to the engine block what connects to the other end of these wires?
Old 07-24-2004, 07:30 AM
vichang4's Avatar
Re: 87 930 wiring help
I don't know if this will be much help, but on my 87 930 that wire runs to the engine and joins into the engine wiring harness. It eventually ends up as part of he wiring harness on the left side of the engine (see picture). There is also a plug from the harness that attaches to a male plug in the front of the engine bay. With out stripping apart the engine harness I can't tell which one it goes to. But unless you cut apart the wiring harness this should not be a problem?
The two smaller brown wires also run straight forward to the engine wiring harness that passes through the cowling, and then to the left side of the engine.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 07-25-2004, 09:40 AM
magic930's Avatar
Turns out the white/blue wire is for the cold start injector. The other brown wires are grounds for temp sensors.
Old 07-30-2004, 04:28 PM
