Is my 3.2 going to go soon dut to oil consumption?
I have a 1989 3.2 with 138,000 miles. I bought the car 5 months ago and have noticed that she is consuming a quart of oil every 300 miles.I am not using synthetic either. Is there something going on internaly that I need to be prepared for? Is there any preventative messures i can take to avoid a failed engine? Should I switch to a synthetic?
What is the recommended oil for a high mileage engine? Ron Last edited by rjb; 05-15-2005 at 09:55 PM.. |
up-fixing der car(ma)
That's a lot of consumption...any smoke? If so, what color is the smoke? It's not uncommon for valve guides to go on the 3.2L, depending on how it was driven (putt around=bad). You should probably be prepared for a top-end job. Synthetic won't reduce consumption appreciably, plus your motor obviously needs some work so switching won't do anything. BTW, 138k really isn't much for a 911, but of course, anything's possible.
Bad news but so it goes...could be worse.
Scott Kinder kindersport @ gmail.com |
There isn't any smoke and the oil pressure seems to be ok. Should I contact my repair shop now or what until something goes bad?
MBruns for President
I would just start budgeting - get a couple of recommendations for shops - then take it in. Has it started fouling plugs yet? That's when I would take it in. Don;t wait too long or you have a chance to drop a valve - that tends to get really expensive.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Still Doin Time
Pull the plugs and look at the business end. If they are oily wet, you're at rings being the issue. If they are coated with white/yellowish matter, it is the guides.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Friend of Warren
You are at engine rebuild time, at least a top end rebuild. My 3.2 had 133,000 miles and also was using a quart every 300 miles, but was not smoking. I opened it up and found this:
Kurt V No more Porsches, but a revolving number of motorcycles. |
So what should I expect as far as $$ for a top end rebuild? I'm in Orange County CA and talked with Andial and they quoted $5000 to $7000 just for a top end. This seems very high.
What is the norm for price? |
I can usually do top-ends for $1,800-2,500 (no major damage like dropped valves, etc.).
Scott
Scott Kinder kindersport @ gmail.com Last edited by YTNUKLR; 05-19-2005 at 12:22 AM.. |
YTNUKLR - wish you were closer...
