Send a message via AIM to fizzzzz
BPU for turbo porsches
What are some basic performance upgrades for a 930 3.3T? This question pertains to hp and engine modifications. From my expierience with turbo cars bpus mean mods that are needed to upgrade to a larger turbo(s). Im assuming it would be exaust, boost controller, intake, and some sort of fuel injection with an afc. Then there are other variables in different cars that would require upgrading if the stock setup couldnt handle the increase in cfms from a bigger turbo. From the 930s that ive seen with aftermarket turbos many of them had aftermarket intercoolers as well. I know very little about these cars but the more I learn about them the more curious I get and this was just one question I had in mind.
Old 08-11-2004, 06:36 PM
350HP930's Avatar
In addition to doing a search you might want to check out the link in my sig.
There is a bit of good 930 info here on this board.
Old 08-12-2004, 12:29 AM
WydRyd's Avatar
Some basic upgrades would be:-
Aftermarket headers and muffler
A K27 Turbo (K27-7200 ~ 450HP or K27 High Flow ~ 550HP)
Aftermarket Intercooler
1.0 Bar Boost Spring
Appropriate fuel enrichment mods
Some more extreme bolt-on upgrades are:-
Convert from CIS to EFI Manifold
Run aftermarket Engine Management System
Internal engine mods:-
Twin Plug the heads
Machine heads for 7.5:1 C/R
ARP/Raceware headstuds and rod bolts
Perhaps even a 3.4L or 3.5L big bore P&C kit
964 Crank
More aggressive CAMs
With the above EFI mods, you'll probably need a bigger more efficient Turbo than a K27, so perhaps a Hybrid Turbonetics or Garrett unit
Hope that helps
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-16-2004, 05:48 PM
