Licensed User
Shuie's Avatar
Steam cleaner for engine case?
Has anyone ever used one of these to clean their engine case? Do they work or should I just buy more carb cleaner and keep scrubbing? Case is about 90% clean already, I just want to finish it up without going through too many more cans of carb cleaner and engine degreaser.
TIA
Old 08-15-2004, 04:15 PM
Friend of Warren
Sherman, I used brake cleaner, as many on this board do. It seems to be under higher pressure in the can and does a much better job of dissolving the gunk inside and outside your engine. Evaporates faster and is cheaper than carb cleaner which really only does a good job of dissolving gas varnish.
Kurt V
Old 08-16-2004, 05:31 AM
Licensed User
Shuie's Avatar
Thanks Kurt! I'll go to the brake cleaner instead of the carb cleaner.
Is your case still pretty dry?
Old 08-16-2004, 05:56 AM
jluetjen's Avatar
Brake cleaner is still pretty nasty stuff and not particularily safe to the environment. I've started to use odor-free denatured mineral spirits (about $5/gallon at east coast paint stores) in a standard Harbor Freight tools parts washer and it really cuts the grime well.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-16-2004, 08:38 AM
I would rather be driving
jpnovak's Avatar
I have one of those $20 steam cleaners. It works well as long as there is not caked on crud. use it for the final cleaning with a scotch-brite pad.
Mineral spirits and an old tooth brush will also work wonders.
Old 08-16-2004, 09:46 AM
Navin Johnson
TimT's Avatar
Bring the case to a local auto transmission place..
They have large industrial "dishwashers" that they clean parts in..
The guy down the street from me has cleaned a number of my cases ( tranny and engine) and hasnt charged me yet.
I did force $20 on him last time I had something cleaned.
When you get the case home just use the brake cleaner for touch up work....brake cleaner is some nasty ****...
'69 911 GT-5
'75 914 GT-3
and others
Old 08-16-2004, 02:11 PM
Friend of Warren
Not a drop after 2000 miles!
Kurt V
Old 08-16-2004, 07:17 PM
