up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Where to rebuild cylinder heads?
Looking for a reasonable place that does cylinder head rebuilds, in L.A. area. edit See new thread.. Thanks!
Scott Kinder
kindersport @ gmail.com
Old 08-12-2004, 11:17 PM
Now in 993 land ...
aigel's Avatar
ebs www.ebsracing.com has a service that seems very affordable. Anyone here dealt with them? I think they have a good reputation, however, I am unsure if they do it themselves or if they aren't outsourcing it. Anyone know?
George
81 SC (sold)
Old 08-13-2004, 01:13 AM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
I brought mine to Dick at Engine Machine Service (EMS)
310-641-7019 near LAX. They did an awesome job and were very eager to answer all of my dumb questions. They also seemed to have the most competitive pricing on head work without a lack of craftsmanship.
100% percent satisfied customer!
BEFORE
AFTER
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 08-13-2004, 02:52 AM
AASE bros in Anaheim (Randy) did my 2.7 heads. Very reasonable pricing and great work!
Chris
Old 08-13-2004, 08:34 PM
I used EBS Racing. Mine came back great!
Brian
Brian Keith Smith
Old 08-14-2004, 06:17 AM
vichang4's Avatar
I used Competition Engineering and they did a great job on an unusual rebuild. CE
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 08-14-2004, 09:58 AM
Try not, Do or Do not
Henry Schmidt's Avatar
SUPERTEC PERFORMANCE
Faster turn around than most others listed. Prices are comparable.
Henry Schmidt
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-14-2004, 08:43 PM
EMS did a great job for me and are very easy to talk to. Besides, they love VWs and Audis too!
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 08-15-2004, 10:49 AM
The heads in the picture of the berfore and after work are not the same heads. Did the shop that did the work send you back a set of heads from another motor?
Old 08-15-2004, 04:19 PM
smestas's Avatar
Nope they were all the same ones that I sent to them. I made sure to stamp them all before they all went out. I might have a miss matched set since the motor was gone into from the previous owner. I never noticed anything different about them, please tell me what you see?
Simon Mestas
'78SC Coupe
Old 08-15-2004, 05:53 PM
dtw dtw is offline
GAFB
Casting dates are different.
Several BMWs
Old 08-15-2004, 10:07 PM
Warren Hall Student
Bobboloo's Avatar
I've used Ollies and EMS. I personally prefer Ollies even though EMS is about four blocks from my house. The downside to Ollies is they are in Santa Ana (long drive), they get swamped and sometimes it takes them a while. Also, Ollies is cash only.
I've heard great things about CE and Supertec but havn't used them personally.
As far as casting dates I don't think it's uncommon to have heads cast in different months i.e. 10-77 and 11-77. It looks to me like the (before) head on the far left might be a 10-77.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 08-16-2004, 12:22 AM
smestas's Avatar
Thanks guys!
I was starting to worry. I went thru all of my older images of the heads before and after and I do see that there was one in the set that has that 10-77 stamp. All the others have a 11-77 stamps.
Good eye on catching the different dates Christian.
Simon Mestas
'78SC Coupe
Old 08-16-2004, 12:51 AM
No, I saw the dates that were different, but the heads in the before picture, at least from what I can tell from a photograph, have a groove cut into the mating surface for a sealing ring, and, again, photograph and depth perception being difficult, there is no way that he milled a small amount off of those heads in the before picture and got them to flatten out like the ones in the after picture. Usually you clip maybe .010 from the surface, those grooves look like they could be .050 deep- thats why I said that they are not the same heads, along with the date thing.
Plus, see how the intake valve seems to be higher on its seat in the before picture, and in the after pic, it buried down more in the head. Even if you do guides, and touch the seats to get them to come home, there is no reason to have to do that much cutting or grinding, whatever the method your shop used to get the valve to seat in properly by taking it that far. You lose compression, and you also lose valve lift since now the valve has to travel an extra .015 lets say before it breaches the chamber. I have seen so many heads that get brought to me to do, that have had a valve job done that just buries the head of the valve so far down the seat, that they need to have the seats replaced. Not only that, the seat cutters that often get used, will leave a sharp ridge right where they stop cutting, which disrupts the flow into the chamber after it passes the seat.
When I do a valve job, I wet grind the seats, which takes longer, gives a better finish and can be more consistent, but you can sneak up on it, rather than getting it done, all 3 angles in one shot with cutting, and winding up with a disaster if done incorrectly.
Old 08-16-2004, 08:39 AM
Warren Hall Student
Bobboloo's Avatar
Not trying to to pick a battle or defend EMS but the "groove" in the before picture is actually a bit of an optical illusion. It's really just carbon build up from the groove that's cut into the cylinder (not the head) to hold the CE ring gasket.
As for the intake valve that's riding low, that's another thing altogether. Like I said before EMS is four blocks away and I've got them resurfacing a flywheel for me as we speak but some things I would drive the extra distance and pay the extra cash for. Head rebuilding and case prepping are two that come to mind. I believe their work is adequate but when I start on my next project motor a 2.8 MFI 9.8:1 motor the case and heads will probably go to Ollies or Supertec.
Bobby
Old 08-17-2004, 01:49 AM
smestas's Avatar
It is a optical illusion that was left there from the CE ring. As for the depth of the new valves I opted not to replace the seats and just had them recut/grinded so that and optical illusion make it probably seem alot deeper then the original image.
Simon Mestas
'78SC Coupe
Old 08-17-2004, 02:16 AM
