up-fixing der car(ma)
Can I rebuild heads myself?
Can I have the valves reground, the valve seats/guides replaces, get new springs, retainers, etc., and rebuild heads myself? Thanks
Scott Kinder kindersport @ gmail.com |
Now in 993 land ...
You are basically asking if you can assemble your heads yourself. Yes you can. It may not save you any money though. I would want mine assembled, that way things don't get mixed up.
George |
No Expert
The tricky part is setting the spring height. You need the right tools to measure it accurately. Remember, the spring height changes depending on what cam you are using and for some aftermarket springs. On my last engine, I had the machine shop replace the valve guides and grind the seats, and I did the head assembly, but I was replacing all the valves and springs anyway, and had not picked my cam yet. I doubt it saved any money.
Good luck, JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
You can set the spring height without the special tool, it just takes longer. Put head together without stem seal and outer spring, use a dial caliper to measure spring height.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
The cost savings would be minimal. I'm a hard core DIY'r but I leave head assembly to the guys that do it every day.
If you're planning to this for a living down the road then now is as good a time as any to start gaining new skills.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Air Medal or two
M.O. look for a seat faceing set (ebay?) you probly do not need a valve grinding machine (replace the valves with new).....now you can do the seats the way you want (after you replace the guides)... I am a firm beliver that I am the only one that will do a valve job the way I want it ,,and it is not that hard!!
It is nice to have the valve grinding machine thoe cause you can take your time and blend it all in....like the seats
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Do any community colleges in your area have automotive classes?
The school I went to for Automotive technology is De Anza College in Cupertino CA. They have a really good valve service and shortblock course offered in the evening. You even get some hands on. The ebay idea for seat grinding equipment is ok, but... the stone arbors wear out, the pilots wear out and unless you have a valve seat runout gauge you might never know. I have also seen brand new valves with as much as .0015" indicated runout on the face. I am not a cylinder head machinist, but I have some equipment and the knowledge to do the work and I still send the heads out to someone who does it everyday.
John Dougherty Dougherty Racing Cams |
I though the valve guides or heads had to be heated for install ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Irrationally exuberant
It costs me about $400 to have a set of heads done (labor and parts) if the valves don't need to be replaced and I get them back in a few days. Years ago I got a quote (just for labor) from the machinist who does the head work for a friend of mine and it was almost that - and that local machinist only does a set every year of two.
The back of Peter Zimmerman's book "The Used 911" has a good explanation of how 911 heads are rebuilt. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Air Medal or two
you are about to aproach a religion here....but this is how I did mine and it works for me.
knock your heads apart and clean them to the bone size you guides to the heads.....you may have to turn a little off the guides (if they have been done b4 maybe not. ) make sure you get std. od. guides (from mom). now if the size to bore is remotly close this is what works- wait till wife goes shopping, preheat heads to about 300 deg. in her oven. have your guides on DRY ICE (safeway sells it) 1 head at a time from oven and slam them in . if I remember I had a little baby powder there to eze the friction re heat the heads a couple of times to get everthing relaxed so you valve job dose not change later. ez part is done
do you really want to do your first valve grind on your own 911 heads? the technique takes a while to figure out. you don't just grind until it cleans. after the 45 is cut, it also has to be narrowed from the top with a 30° stone to both true the top edge, and size it so the valve just overlaps it, and then cut from the bottom with a 60° stone or hand cutter, to both true it to the top edge and narrow it to the correct width. (i use a hand cutter because i can take off metal where i want, as the stone tends to follow the hole). there is only so much metal to work with, and only the minimal amount should be worked. too much grinding drops the valve too far in and ruins the seat. some seats are pretty wallowed out from the valve beating around from a loose guide problem and you often have only one chance to save the seat if you're good. then it's seat replacement time or another head. not that you can't do it, but beware.
as for replacing guides, the best way is to drill 1/2 way through with a step drill, leaving just a thin shell of the guide, then using a stepped drift to drive them out. can't say i've ever heated a head to remove or install guides. mic the diameter of the old ones and compare it to the new ones. the guides i get from worldpac are usually just a couple hundredths of a mm oversize and using WD40 as a lubricant on the guide and in the bore, drive in quite nicely. i use a guide driver tool in a air hammer with a thick washer slipped over it so the top of the guide isn't damaged. easy on the trigger.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 08-15-2004 at 03:57 PM.. |
Old Member
John
Can you recommend a source for guide reamers you're using and part numbers ? I have the K-Line catalog. Where do you buy your stones for seat grinding? What part numbers for the stones, I have a Sunnen catalog. Are you doing a three step cut on the seats. Thanks Cliff Brown
Clifton Brown https://www.mancalamarketing.com |
Air Medal or two
soux machine, snap on , ect. ect.,......all you have to know is which size valve stem,,I usually do it in 2 step process ,,dono why just do.
like Jn W. drill out the guides......... I have for got the size weather it's a 9 or 10 Mabe Jn W. will tell you ,, but you have to go a couple thou. bigger then your stem
