I've had leak down test on an 84 911 with 135K miles that I am looking to purchase (my first 911) . The results were 7% 5% 5% 6% 10% and 5%. Should I have a compression test done also? If so, what would a compression test show that a leak down would not show? At this point I am only interested inthetest to make sure I am not getting into something with serious engine trouble. Thanks.
Mike '84 911 Carrera Coupe (totaled) '83 911 SC Coupe ‘06 Aston Martin Vantage V8 |
Author of "101 Projects"
Check out this article:
http://www.pelicanparts.com/techarticles/mult_Engine_Rebuild/mult_engine_rebuild-1.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
Thanks for for your response. I've already read part one and part two of the article which were very good. I also purchased a copy of your book on 101 projects. I understand that a leak down test is a static test and a compression test is dynamic. I also understand that most everyone reccomends getting both tests done. What I don't understand is, what problems could a compressions test point to that a leak down could not. I was thinking of something like a bent valve stem. Thank you.
Irrationally exuberant
A leak down only checks the very top of the cylinder (and at a small fraction of the operating pressure). A cylinder that was scored/scratched part way down but not at the top might test fine with a leakdown. Good cylinders can have bad leakdowns and visa versa.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Leak down tests and compression tests will often give different results. Leakdown tests are useful to determine where a problem lies - compression tests are good for checking the overall health, including cam timing, etc. I would get both tests done...
-Wayne
Friend of Warren
Anytime I see a leakdown greater than 5% I start looking around for problems.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks for the feedback. I went ahead and had the compresssion test done. Here are the results: (compression/leakdown)
Cyl 1: 165# 7% Cyl 2: 172# 5% Cyl 3: 175# 5% Cyl 4: 175# 6% Cyl 5: 175# 10% Cyl 6: 173# 5% Based on the results I went ahead and purchased the car!
arigato,
Those are good numbers. Take your new 911 out for some spirited driving and re-test. I’ll bet the numbers improve and even out. You will now have a good base-line for continued monitoring of your engine’s condition. With the right tools this is an easy DIY regular procedure. Enjoy! BTW, welcome to Pelican. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Grady,
Thanks. Fortuantely I bought the car 130 miles from home so I had a good chance to test it out on some turns and highway. What a car! I was blown away by the handling in the turns. On the highway it was just purring along at 80 mph. Very addictive.
