Targa, Panamera Turbo
M.D. Holloway's Avatar
Copper or Yellow Metal Alloys in 2.7L Engine?
Does a 77, 911, 2.7L engine contain any copper or yellow metal alloys that the engine oil will come in contact with?
Michael D. Holloway
https://5thorderindustry.com/
Old 09-01-2004, 08:19 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
It could also be metal from worn out bearings
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-02-2004, 05:50 AM
Irrationally exuberant
ChrisBennet's Avatar
Off the top of my head the only yellow metal (not counting yellow zinc fasteners) I can think of is the distributor gear on the the crank shaft. I think that is brass.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-02-2004, 05:54 AM
Tim Walsh's Avatar
Here's a pic of what I'm refering to
Splitting the case pays off
Tim
1973 911T
2005 VW GTI
Old 09-02-2004, 06:39 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If you're talking about gold in your strainer, you're done!
The only cooper or gold (yellow) colored metal in a 911 2.7 engine is the rod bearings (small end), distributor drive gear, and rod, main and intermediate shaft bearings.
If you're seeing gold in your oil there is something very wrong.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-02-2004, 07:38 AM
Guys - great info. Thanks! The reason I am wondering is that in certain instances, dissimilar metals (copper or yellow alloys and ferris alloys)can create a galvanic corrosive situation. This process hastens when the acidity of the engine oil increases. As the acidity increase and corrosion ensues, deposits begin to form and oil performance additves get quickly consumed. I've been doing some research into it. The process happens at an exponential rate function. I am attempting to design an engine oil that will lessen this condition thus extending the life of the oil and reducing deposit build-up. I am planning on finishing out the lab tests then trying it in my engine. After the results are in, anyone who wants to try it, feel free to e-mail me and I will get you some at no charge. I just ask that you share the data with me. I will provided more specifics if you like - feel free to e-mail me.
Michael D. Holloway
Old 09-02-2004, 12:44 PM
