Valve Springs Upside Down
Hi
I've just finished the long block and have now learnt that I should have oriented the Outer Valve Springs, I don't think this is a major though I could change them. Any comments TIA Neven 73 911E 'Eva' 70 914/6 'Eric' |
the bottom of the spring has slightly tighter coil
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Yes, but is it critical? The only reason I can think for orientating them is that this lessens the moving mass
Neven |
Yes its critical, an upside down spring would put more strain on the rocker arm ......... check all 12 of them
The spring should have the same tension characteristics regardless of which end gets pushed. If the spring is progressively wound, the lower tensioned portion will compress first.
However, the tighter wound end would be slightly heavier, thus you don't want this end moving as much (with the rocker arm). How does that sound? Sherwood |
No to be arguementative, but the moving mass is at issue when it comes to compression. That's why progressive springs always have an orientation depending on application. If what you said were correct you could spring a sus system any old way. That's not the case though. Progressive springs always mount in one direction only, depending on where you want the load given the mass. I agree it is critical to mount the springs correctly as the initial movement of the valve needs a lessor spring rate for control in the start of it's stroke.
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
Author of "101 Projects"
I tend to agree with Sherwood's statement. As a mechanical system, the spring should respond to compression (not tension) in similar manners, regardless of whether it's placed in one orientation or the other. The force on one end is countered by an equal and opposite force on the other. Reducing the moving mass would mean putting the heavier part closer to the chassis.
I'm just speculating here - I don't know for sure. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
In regards to the Springs they are basically Non-linear in design.
This manufacturing process effectively decreases the number of active coils as the spring is compressed and the rate increases. It does not have a single natural frequency but passes through a range of natural frequencies instead. It does not effect the rate but the harmonics. It is a little more complex to manufacture and is not the cure for a materials issue. Best regards |
