cassidyp's Avatar
Are there two sizes for circlips?
Hi. Me again. Just received my order for circlips. I checked and they are 22mm inside diameter. When installing them I have an overlap? Should I be using a different size? I Am trying to find one of the ones from my removal process to check but would appreciate any advice. 2.4 with original pistons and cylinders.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 09-28-2004, 05:19 PM
dtw dtw is offline
GAFB
Cassidy,
I had the same experience - I purchased OEM Porsche clips from Pelican and there was quite a bit of overlap. I used a good pair of cutters and trimmed the clips down so that they fit in the piston like the old ones did. Wear good safety glasses when you do the cutting!
I did re-check the part numbers after the fact and everything was kosher.
Several BMWs
Old 09-28-2004, 05:44 PM
cassidyp's Avatar
Dave,
Thanks for the quick response/ suggestion. Was your experience with overlap of the circlip on a 2.4 liter engine rebuild? I wish I could find one of the ones I removed and measure it.
71 911 Targa
Gruppe B # 3911
Old 09-28-2004, 06:28 PM
Irrationally exuberant
ChrisBennet's Avatar
The piston wrist pins went from 22mm to 23mm with the '84 Carrera and (I believe) with the 3.3 Turbo. Maybe the 23mm clips overlap if you use them in a 22m wrist pin hole?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-28-2004, 07:39 PM
cassidyp's Avatar
Chris, These are to fit in my 2.4 T engine. It seems that somewhere I read that 18mm size is correct. This looks about right. The ones I received are 22mm
71 911 Targa
Gruppe B # 3911
Old 09-29-2004, 06:05 AM
