Larger Venturies for my Webers?
I have removed the Weber 40IDC 3A carbs for a rebuild.
They currently have 32mm venturies.
Will larger venturies give more top end power?
The engine is 2.7 from a '77 911. Internals (P/Cs, compression ratio, Cams) are unknown. Bursch Headers with megaphones (with removable baffles).
The car is 90% track. Weighs less than 2100lbs.
Eddie
Old 10-19-2004, 06:38 PM
PRO Motorsports
Tyson Schmidt's Avatar
What size ports? I think a '77, assuming they are '77 heads, should have 35mm ports.
I'd use 34mm venturis. You'll need to rejet after the change. Slightly larger idles and mains.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-19-2004, 07:20 PM
No Expert
jgparker's Avatar
For 90% track, I'd go as large as you can stand on the venturies. I found 36mm venturies on my 2.8 to be a good compromise for max high RPM track power but with adequate street drivability. Talk to an expert, like Richard Parr at PMO to get a recommended starting point for your set-up, but you'll need to know the internal details of your engine.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 10-20-2004, 05:53 PM
iobound's Avatar
Send a message via AIM to iobound
If you are interested in selling the 32mm venturis I'll buy them.
Daryl
RPM also stands for Redhat Package Manager
16 year PCA Member
NASA Member
1988 944 NA w/4valve S motor (Daily Driver)
1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen)
1998 Volvo V70 Wagon
2002 Barbie Electric Kids Jeep
Old 10-22-2004, 03:40 AM
Super Moderator
cstreit's Avatar
Larger venturi's will give you a bit more flow (assuming the jetting and port sizes will accomondate, as Tyson and others mentioned) but will also reduce your low RPM throttle response.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-22-2004, 06:46 AM
