Plavan's Avatar
Thanks Mark. I think that may be the plan to break it in. I just have to get the towing\trailer logistics down (sold my tow truck and have not replaced yet)
Just got some new pictures!
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 11-01-2004, 07:37 AM
126coupe's Avatar
Nice! So how do you plan on getting the "tow" thing sorted out??
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 11-01-2004, 07:40 AM
Plavan's Avatar
I may just be throwing a hitch on the company car (shhhh. do not tell my boss) for the time being. Then pick something up in the off season.
Chad Plavan
Old 11-01-2004, 07:43 AM
Az911's Avatar
Send a message via AIM to Az911
That's the best solution I've heard.
Old 11-01-2004, 07:52 AM
126coupe's Avatar
Dude "Throw on a hitch" Please not the kind that u Haul hooks to the bumper. Car might end up in a ditch
28' Pace Trailer
Old 11-01-2004, 07:56 AM
Plavan's Avatar
I ordered a real class 3/4 hitch. No worries. Just have to find a way to expense it
Chad Plavan
Old 11-01-2004, 08:05 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
You can use my other trailer....... You can expense that too.
Only $220 to use it..... Hey maybe we can trade for something?????
LOL
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 11-01-2004, 01:48 PM
Plavan's Avatar
One more pic before the shroud (It is being painted black) goes on.
Chad Plavan
Old 11-05-2004, 07:16 AM
Plavan's Avatar
Here is the Dyno sheet at the Rear Wheels . (for Searches)
Chad Plavan
Old 08-20-2005, 02:06 PM
Nice Chad
Well Chad,
Your 2.5L has about 57 more HP then my 2.0L and you are about 100 lbs. Lighter then me as well.
This should make for a fun race in Buttonwillow.
What was JP's Motor putting out????
Mark Scott
Vintage 911 Racer
Old 08-20-2005, 04:48 PM
Plavan's Avatar
JP was busy and could not come. 57 more HP? Won't believe it unless I see it (Wink)
Chad Plavan
Old 08-20-2005, 05:17 PM
OK. Maybe 55 more HP.
I have 162 at the rear wheels. with 158 ft lbs. of torque.
Mark Scott
Vintage 911 Racer
Old 08-22-2005, 08:08 AM
ttweed's Avatar
My stock, tired, 2.0S engine made 130 RWHP on a Dynojet. Those are some impressive numbers you guys are getting.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 08-22-2005, 09:26 AM
Warren Hall Student
Bobboloo's Avatar
Beautiful motor and some impressive numbers. Congratulations!
Do you think the dip at 4400 can be improved with jetting or is it just the nature of the engine design? i.e. 2.5L, GE80, and large ports.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 08-23-2005, 11:50 PM
Plavan's Avatar
Thanks-
I asked the same question to the motor builder who was there with his car. It's just the aggressive cams causing that. They are getting ready to start their magic. Since this is a race motor..... I am never at 4400 RPM and never notice it.
Chad Plavan
Old 08-24-2005, 12:24 PM
al lkosmal's Avatar
Chad,
You set the bar high.
Al
RGruppe #669
http://www.x-faktory.com/
Old 08-24-2005, 07:34 PM
Cornpanzer's Avatar
Beautiful motor! What kind of budget would it take to replicate this motor not including the labor from the builder?
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 10-03-2005, 01:48 PM
Plavan's Avatar
Here is the cost breakdown assuming you already have a Aluminum case with all the basic mods and cams.
Main bearings 125
Rod bearings 75
Intermediate shaft bearing 45
Gasket set 250
timing chains 80
chain rails 39
46mm PMO Carbs New 2800.00
J&E custom pistons 900.00
oil return tubes 26
rebuild rods 132
balance rods 35
port/polish heads 39/37mm 500
boat tail mains 200
moon cylinders 85
weld injector ports cis 180
surface heads 120
hot tank, polish, mag crank 60
arp rod bolts 155
valve guides 48
drain plate with drain plug added 25
rocker arm shaft seals RSR 31.20
piston ring set 125
flywheel bolts 66
distributer drive gear 22
Gold zinc all bolts/hardware 25.00
fan belt 5
oil line clamps 2.50
gloss black paint 5.50
Total not including labor $6162.20
-Chad
Chad Plavan
Old 10-03-2005, 01:57 PM
Cornpanzer's Avatar
Thanks Chad!
This may be out of your area of expertise, but would this be compatable with a 2.2 S MFI system?
Dave
1970 911S,
RGruppe#252
Old 10-03-2005, 03:34 PM
Plavan's Avatar
I know nothing about MFI except that my old 2.2S mfi system had a mind of it's own . Should work if you have the pump changed/worked on.
Chad Plavan
Old 10-03-2005, 04:52 PM
