H.G.P.'s Avatar
How much can I do without sophisticated Porsche tools?
I have the motor out, and have some specialty tools (torque wrench, tools I used for installing flywheeel last year, etc.,).
However, I've never removed heads, valves, pistons, etc. Can I get through with regular sockets, etc.,?
What can I do with the Porsche motor out with just "basic" automotive tools? Seals?. valves? cylinders?, oil tubes, etc.
How far can I go here?
Thank you.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 10-31-2004, 12:02 PM
walt's Avatar
As far a getting things apart you will need a engine stand, engine stand adapter ring , camshaft tool, stud remover, flywheel and heat exchanger tools. Those would be the minimum basics. Check out this link. http://www.pelicanparts.com/cgi-bin/wizards/Parts_Wizard.cgi?command=step2&wizard_root=911_engine_rebuild
Walt
82SC 3.0
81SC 3.6
Old 10-31-2004, 01:44 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Really, you can put the engine on a very sturdy table or even leave it on the floor...you can get much done with sockets, 10mm-19mm, a breaker bar, wrenches from 13-18mm, and an allen head 10mm key for the head studs. You should also have needle nose pliers, soft rubber malet, not too complicated.
Scott Kinder
kindersport @ gmail.com
Old 10-31-2004, 02:21 PM
Old Member
A 46mm socket will work to get the cam nut off. If you already have the tool for the flywheel bolts, then you're OK.
Clifton Brown
https://www.mancalamarketing.com
Old 10-31-2004, 04:56 PM
oneblueyedog's Avatar
I can't see how you can get the cam nuts off without the "rite of passage" crows foot wrench and cam holding tool. The engine is just too special to not get special tools.
Get ready to get a dial gauge and holder to time the cams too.
78SC coupe, Silver Metallic
Old 10-31-2004, 05:35 PM
H.G.P.'s Avatar
OK thanks, initial diagnosis is broken upper #2 rocker arm, that may be NLA. And worse, down the spark plug hole (same cylinder #2) I can see dented/mangled metal).
So I may just see how far I can strip everything down with the tools I have to get under #2 cylinder.
Thank for the tool info.
1969 911 E Coupe
Old 10-31-2004, 05:45 PM
I would think you would only need the cam tool as long as you can get the exhaust off. I would think you would want to get an engine stand and special yoke. It will save you loads of time.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 10-31-2004, 07:49 PM
Irrationally exuberant
ChrisBennet's Avatar
I hate to sound like a broken record but perhaps if you added your location to your profile you would find that one of your Pelican neighbors would be willing to lend you the tools....
You don't need much in the way of special tools to disassemble that motor except for the cam nut tools. Reassembly will require a "Z block and dial indicator for setting the cam timing. The most important "tool" you'll need is knowledge. Get Wayne's book and do your research. To do things right you'll also need some measuring instruments (calipers, micrometers, straight edge, etc) or a machinist to measure things for you.
I find my digital camera to be invaluable for documenting things so when I reasseble them weeks (or months) later I know how things were assembled, where brackets were mounted, etc.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-01-2004, 06:42 AM
rick conrath's Avatar
I agonized over buying the special 993 camshaft tools to remove the nuts...in the end an impact wrench did the trick (and I can use it for other things as well). Wish that I had bought it before I struggled with the main pully nut.
Rick
'78 930
Old 11-05-2004, 12:45 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, you can get the nut off with a socket. But you will stretch and damage your chain. Fine, if you're not re-using it again, but you can't install the new nut without the proper tools, without damaging the chain.
-Wayne
Old 11-06-2004, 02:48 AM
Wayne 962's Avatar
Rick
'78 930
How did you reinstall them?
-Wayne
Old 11-06-2004, 02:49 AM
