Change the pulley seal too?
Since my top end rebuild this past winter, I noticed that she's leaking from what it seems to be from the flywheel seal. So now I have confirmed that it is. Good news is everything I did worked flawlessly. Bad news is that the leak is from somewhere that I didn't even touch
So my question is: "while I'm there", should I also consider changing the pulley seal as well? Its not leaking there right now.
And, can I really change these seals without opening up the bottom end?
Thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 11-15-2004, 07:11 AM
Bandwidth AbUser
Jim Richards's Avatar
These seals can be replaced without cracking the case. I wouldn't replace a non-leaking seal. I'm afraid of creating problems where they previously didn't exist.
Jim R.
Old 11-15-2004, 07:37 AM
Hi Jim,
Thanks for the comments - exactly what I'm thinking. Will I create a new problem. I believe the pulley seal can be replaced without a complete engine drop as well? If so, I can wait till it leaks instead of for convenience right now.
Old 11-15-2004, 09:00 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Leave it be. If it ain't broke...............
And yes, in the future you could replace the nose seal without dropping the engine. Just remove the muffler and engine console (with the engine supported of course) and there's a good bit of room to get at the pulley. Just beware that the pulley nut is pretty tight. Big breaker bar or impact wrench is sometimes needed for removal.
Kevin L
'86 Carrera "Larry"
Old 11-17-2004, 06:07 AM
Thanks for the confirmation Kevin.
Leave it be it is
Old 11-17-2004, 06:40 AM
I manage to change the pulley seal with the muffler and engine mount
in place, it's tight but can be done!
F.
Old 11-17-2004, 06:59 PM
Brother's Avatar
Re: Change the pulley seal too?
[QUOTE]Originally posted by hobieboy
[B]Since my top end rebuild this past winter, I noticed that she's leaking from what it seems to be from the flywheel seal. So now I have confirmed that it is.
Do you know off hand what the part number is. One of mine is leaking as well and I don't know which one until I drop the motor.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 11-17-2004, 07:03 PM
