2.7 RS Spec Upgrades
My car has a 2.7 RS Spec motor
With the MFI system can I add a crank fire type ignition without having to modify the pump? Also does anyone think this is more the effort.
Any suggestions on creatinmg more power from this motor beyond going larger. Cams?
Old 11-17-2004, 04:37 PM
drag racing the short bus
dd74's Avatar
Higher compression pistons? That's if you want to tear the engine apart.
The Terror of Tiny Town
Old 11-17-2004, 05:00 PM
Hi
Your best bet would be higher compression and twin plug, Cam would alter the volumetric efficiency and require the MFI pump recalibrated (and their are limited profiles available), Changing the Pistons and Twin Plug would also not require a fullengine tear down
HTH
Neven
Old 11-18-2004, 12:08 AM
