Va914's Avatar
2.2 T carb set up??
Can someone tell me what a good set up (starting point) for some Weber 40's for 2.2T would be?
The carbs I have now have the following;
Idle____50
Mains__ 135
Airs ____180
Venturi__32mm
If they will not work what is a good place to get the new pieces I didn't see them in PParts.
Cheers
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 11-18-2004, 11:54 AM
jluetjen's Avatar
You can get the parts from PMO if they are not available from Pelican.
BTW - What emulsion tubes do you have?
Do you have any issues with the way the engine ran with that jetting?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 11-18-2004, 12:17 PM
Va914's Avatar
New carbs (to me) going on a new to me 2.2 engine.
I don't know what the emulsion tubes size are.
I'll check with PMO.
914-6 in the Werks
Old 11-18-2004, 12:21 PM
Smile
PMO supplied me carbs for my 2.2T and they came jetted as
follows:
venturi 32
main 130
Air 200
Idle 55
Emulsion tubes F11
to run on 91 RON fuel from, car operates from sea level to 2500 feet, and ran great.
interestingly enough richard recommended the same settings would be fine for my soon to be completed 2.4 with 2.2s pistons and e-cams for street.
for a step (racing etc) up he recomended the following for the 2.4e+
venturi 34
main 135
Air 190
Idle 55
Emulsion tubes F11 (or F16)
hope this helps.
nathan
Old 11-18-2004, 01:50 PM
Va914's Avatar
Thanks..
Do you guys think it is worth trying to find someone looking for my set-up, from a 2.4L and swaping them for their 2.2 set-up?
I have 2.2 and don't think what I have will work. I'll start looking for the correct pieces.
Cheers
914-6 in the Werks
Old 11-22-2004, 10:45 AM
Va914's Avatar
Angry
Wayne, I was told by one of your sales guys you don't carry weber carb parts (Only linkage).
kerrys914@yahoo.com
914-6 in the Werks
Old 11-30-2004, 09:34 AM
Va914's Avatar
John Chi
Senior Porsche Sales Advisor
914-6 in the Werks
Old 12-02-2004, 04:15 AM
