Paul Thomas's Avatar
Standard/Standard?
When someone is refering to a crank, why do they say STD/STD? Why not just standard?
Paul
My ignition is retarded.
Old 11-27-2004, 08:26 AM
camgrinder's Avatar
STD/STD means standard size on the rod journals and standard size on the main journals.
John Dougherty
Dougherty Racing Cams
Old 11-27-2004, 09:00 AM
I see. Thanks John.
Old 11-27-2004, 07:07 PM
Author of "101 Projects"
Wayne 962's Avatar
Bearings are the same way. You can have bearings that have a larger outer shell (oversized) to compensate for worn bearing surfaces in a case. Or, bearings that have a larger inner shell, to compensate for worn jounals on a crank.
-Wayne
Old 12-01-2004, 10:39 PM
