2.7 Main Bearings
Does anyone know where I could find a set of 2nd over (.5mm over) main bearings for a 2.7. I have a case that has been fitted with case savers, shuffle pins and a carrera oil pump but unfortunately it was already align-bored .5mm. The crankshaft is standard so I need (STD I.D. / .5mm O.D.) on the main bearings. Any help is appreciated.
the dealer sells 1st over sets for a reasonable amount. don't know about 2nd over. they don't come as a set, you have to order each bearing.
Try not, Do or Do not
To my knowledge there are no .5mm align bore bearings. It sounds like you will need to resize the case. ( pull all the case studs and surface the case halves enough to allow for align bore to standard or most likely 1st oversize.
Good luck
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Author of "101 Projects"
2.7 cases are very common - I would find a used one and go from there...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
You can now only buy these as pairs of shells not as an entire set. I got mine after a LOT of searching because the part numbers have changed. I ended up paying a little over $400. Wayne's right, look for another case. T |
