Where to start Top end rebuild
I bought the book were to start for a top end rebuild
Im in the planning stage right now |
I would rather be driving
Step two, read the book.
![]() I think chapter 1 &2 describe where to start.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
For a top end or complete?
The starting point is the same. Unless you have major internal problems like a spun bearing or broken rod bolt the top end will usually wear before the crank/rod bearings. You also have to tear the top down to get to the case and bottom end.
If you are just planning you need to start by asking yourself what you want out of the engine. First, what car and engine is it? Will it be a street only, street/track or track only? Just a stock rebuild or increase in power? Are emissions a concern? Once you know a base target this will help you decide on the best path to take. Also what is your budget? Do you plan to do the work yourself? Do you have the tools and/or mechanical ability?
Author of "101 Projects"
Read the book, particularly Chapter One. It will tell you if you need to do a full rebuild or a "top end" overhaul...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
