Well, you have the factory specs to go by, and if you have a brand new distributor and a distributor machine, that would verify what it is versus what it should be.
Even the spring attachment points can be tweaked (I think) to change the effective spring rate (and thus the advance curve). Sherwood |
One can check the advance on the motor with a timing light. All you need is the advance graph. If the curve doesn't match the graph change the springs. Summit sells an assortment of advance springs.
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Daryl G. 1981 911 SC - sold 06/29/12 |
Wayne,
If you must retain something as paleolithic as a mechanical advance dizzy, then there is no substitute for having it set up on a dist machine. This after insuring the bearings and advance are clean, corrosion free, in spec, and lubed. A seemingly tiny flaw in this simple device can turn a good engine into a dog. Phil |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
No springs... New O-rings (2), snap rings (2) , several different screws (5), and the six-fingered star apparatus plus the holding pin. I haven't even opened the plastic covering yet since I want to keep everything intact until I plan on installing. I needed another snap ring which was the actual reason I purchased this kit plus I had slightly bent one of the six legs during my initial attempt at the distributor disassembly.
Yes, I got this kit yesterday. Big disappointment for me - no springs. Sortof useless if you ask me.
Oh well, the hunt continues! -Wayne
Party Member
Hmmm,
Well, you know what the current springs are delivering, so you want something incrementally stronger. Have you considered purchasing an assortment of ultra-precision springs from McMaster-Carr and doing the old Trial and Error method?
Gary 71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure |
I figured I'd try sourcing the original springs before the time-consuming trial and error method. I have a few better things to do than to mess with springs
(remember, I have a five-month old).![]() -Wayne
Are you certain the tabs the springs are attatched were not bent in by the PO? It's very hard to imagine that those springs could have lost there tension with so littlle force acting on them. It seems more likely that the tabs were adjusted as I have done many times to get my advance to come in earlier. Of course if you bend the tabs in too much you end up with the situation that you describe...what appears to be weakend springs. -Joe Last edited by stlrj; 12-25-2004 at 10:47 AM.. |
Somatic Negative Optimist
One way to check to see if it's advancing when it shouldn't is to check the timing with a timing light by cranking the engine *only*. Set the timing to TDC while cranking (disconnect fuel pump or CD box, etc). Then start the engine up and check the timing at idle. If it's the same, then you're distributor is not advancing prematurely. If it reads advanced, then you need new springs. How can you get a read on your timing light if the CD box is disconnected when cranking? I can understand to disconnect the fuel pump (Relay) but the CD box? Help!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
-Wayne
Incidentally, the distributor didn't advance at idle, nor at cranking speed. I'll have to rethink this one... -Wayne
Disconnect the vacume lines. If your centrifcal (sp) advance is working, when you rev the motor the timing will advance. So all you do is hook up a timing light and note the advance from idle to 4000 rpm and plot it on a graph and compare to the factory graph. If it advances too fast put stiffer springs in and recheck. If it advances too slow put weaker springs in.
Dean
-Wayne
Wayne, I would assume a distributor shop somewhere could give you a tip on where they source their springs for recurving distributors.
Summit racing or Jegs sells a small assortment of dist. springs. The assortment usually contains 3 sets of springs. Do a search on the respective sites.
Dean
-Wayne
Party Member
Any luck on this quest? Send the measurements on the OD, length & wire d, plus a picture and I can calc the numbers so you can ballpark it from a spring catalog. A photo too and, oh yeah, is it magnetic?
What freekin Oil Leak?
I also got the same indications as Wayne (insufficient advance at high rpm and apparent early advance at idle). My distributor was fine, springs were good – it was another problem.
BACKGROUND My car uses vacuum to retard ignition at idle (you leave the hose connected to the pot during timing). As soon as you press the gas pedal, you lose vacuum and this advances ignition by 15 degrees. As you accelerate, mechanical advance moves it another 18 degrees through 4000 rpm. For me, using the starter as Wayne suggested earlier (which is a great idea) to check early advance doesn't work because I need vacuum at idle. CONCLUSION My problem was that I was not getting sufficient vacuum to the pot at idle. Once I unblocked my vacuum port into the throttle body, I was OK (used copious amounts of carb cleaner). TIDBIT: This is probably something everyone knows (so feel free to correct me if I don't have this right), but it was a revelation to me: I realized when you look at the distributor vacuum advance curve for your car, you need to double the amount on the graph to get ignition advance. For example, for my car, the graph below tops out at 9 degrees total mechanical advance at the distributor. This is 18 degrees ignition advance. [Every 1 degree of rotation at the distributor drives two degrees of ignition advance (distributor rotates once for every two turns of the crank.]
Steve '79 930 US Last edited by TurboBert; 12-31-2004 at 08:13 AM.. |
