Bietendorf
Guest
Posts: n/a
Is Wenol the best for this?
I am just starting the process of pulling the engine and tranny for the first time. I need to rebuild the tranny and maybe install a heater. I recently purchased this car from the east coast. From the pictures you will see the surface corrosion on the mag and aluminum surfaces. I would like to clean this up. Is Wenol the best product for this purpose?
The engine runs great, so no tear down there, except for adjusting valves. So, I will have the valve covers off to polish.
I have read many threads on the rebuild topic, but you guys may be seeing a lot of me in the next few weeks to help this newbie.
Happy Holidays.
Old 12-24-2004, 09:23 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
That engine is quite clean, did you degrease it or something?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-24-2004, 07:41 PM
Bietendorf
Guest
Posts: n/a
No I did not degrease it. It came this way. The stains on the muffler are from rust eater i put on the exhaust studs for removal . There is quit a bit of surface corrosion and I want remove it. Thought I would use wenol product to get it clean.
Old 12-25-2004, 04:50 PM
Irrationally exuberant
ChrisBennet's Avatar
What I see in the pictures is just how these motors normally look.
I would recommend getting some bigger/taller jackstands rather than stacking jack stands on top of something else. The tall ones really convenient as well as being safer.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-26-2004, 04:20 AM
Bietendorf
Guest
Posts: n/a
chris,
Thanks very much for your safety tip. I am always looking for the safest way to do things. To help ease your concerns the stands are situated on welded 2" square tubing jack stand extensions. The car is lifted 30" as measred from the bottom part of the rear bumper. I also fabricated a custom attachment to an ATV lift to lower the engine and tranny. I wanted plenty of room to drop the two. I use to be a certified welder and would trust my life with my welds.
As for cleaning the engine, the corrosion is not real visable in the photos. I decide to order some Wenol. My plan is to detail the engine, engine compartment, suspension parts and uderbody, while the car is lifted and the engine is out.
By the way. Can someone verify that I have upgraded turbo valve covers from the picture?
Old 12-26-2004, 11:00 AM
Yes, those are Turbo lower valve covers. "Turbo covers, ribbed for her pleasure." Even those can warp so check them for flatness if you have leaks. People tend to overtighten them to stop a leak and warp them in the process. The torque on those nuts is very low.
Looks like you've got all winter to clean your motor.
stay warm,
Chris
Old 12-26-2004, 12:26 PM
