H.G.P.'s Avatar
Page 128, how many bearings get assembly lube?
1. Does bearing shell #1 (closest to the flywheel end)?
2. Does underneath no. 8 bearing also get assembly lube?
Thanks1
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-28-2004, 02:07 PM
Irrationally exuberant
ChrisBennet's Avatar
All bearings get assembly lube. They will be momentarily totally dry of oil when you start the motor.
The #8 bearing gets lubed by applying it to the nose of the crank before you slide the bearing on. "Underneath no. 8" bearing" is not a bearing surface - the crank spins inside the #8 bearing. (I heard your hand smacking your forehead now so I won't belabor the point.) Some people put a small/thin amount of non-hardening sealant around the #8 bearing - not the orange case sealant.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-28-2004, 03:11 PM
Friend of Warren
if it is a bearing, it gets lube
Kurt V
Old 12-28-2004, 03:58 PM
H.G.P.'s Avatar
-Chris
Wanted to be very certain, thanks. If you do put non hardening sealant around the 8 bearing, is there a risk of some coming off in the crankcase?
Is there an o-ring used after the flange bearing before the flywheel? I see there is a circumfrence groove in the crankshaft just before the flywheel seal. (see below)
1969 911 E Coupe
Old 12-28-2004, 04:57 PM
Author of "101 Projects"
Wayne 962's Avatar
That is a channel for oil flow - not for an o-ring.
See Figure 3-22 for a fully dressed case.
See text on Page 128 - lube the crankshaft nose, or inside of the number eight bearing prior to assembly.
Don't forget to lube the intermediate shaft bearings either...
-Wayne
Old 12-28-2004, 05:14 PM
H.G.P.'s Avatar
OK.
1969 911 E Coupe
Old 12-28-2004, 05:37 PM
That's a good question/concern. I have a perhaps irrational dislike for silicone/RTV for that very reason.
If you put too much, yes, "boogers" may squeeze out, break off and plug the small places in the oil system. You don't want to put it on thick around #8. Think paint or sunscreen lotion thickness, not cake frosting thickness. Does that make sense?
The sealing surfaces on 911 motors are so close that they would almost hold oil without sealant. If your motor hasn't been apart since it left the factory, examine how little sealant there is between the cam carriers and the heads.
-Chris
Old 12-28-2004, 07:14 PM
Wayne 962's Avatar
There's an o-ring in there. If you want some reassurance, simply put a little Curil-T on there...
-Wayne
Old 12-29-2004, 12:50 AM
