Hbrand
Head Studs, how to be sure??
Is there a test methode to see if the studs are not slowly pulling out?
I thought like this: put a strong small pipe over the head stud, washer and head nut - and apply torque. So how much can I go? The studs look fine right now but when I disassembled the engine the head nuts where all diffferently and not so tight. Thanks, harold
Cheers 1982 Porsche 911SC Euro 1969 Mercedes 280SL 1956 Austin Healey 3x |
Friend of Warren
If it is a magnesium case I would just timesert all the headstuds.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Author of "101 Projects"
If it's a magnesium 2.7 case, then they are pulling. 99.9%
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
no so tight head nuts is probably what caused the base gaskets to get squeezed out.
-Wayne
Friend of Warren
Wayne I think you and John are saying the same thing. And I agree that the loose head studs caused the damage to the base gaskets.
squeezed, beat, pounded, whatever.
![]() -Wayne
