Hbrand
hbrand's Avatar
Crushed Copper shims!?
When disassembling my engine, I found the copper shims crushed and squized out at the bottom of the cylinders.
What can I replace those soft copper shims with??
One more please:
Are this Mahle or JE pistons?
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 12-27-2004, 03:42 PM
Autobahn Garage
Those are copper base gaskets I think the host sells them. There not very expensive. The piston look like a Mahle to me I may be wrong? But I don't think so? Get Wanyes book: How to rebuild and mod your 911 engine, All your questions will be answered
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 12-27-2004, 05:24 PM
Autobahn Garage
I just saw that you bought the book! Good going
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 12-27-2004, 05:25 PM
Hbrand
hbrand's Avatar
Hello wayne
will post more piston pictures tomorro.
because of the crushed and slipped out cooper shims, the cylinders leaked at the cylinder head. So I gues i can only use the most thick once I can buy.
Can I post all the parts I need to order here and you give my the part numbers, or can your sales people handle zb ring set 92mm, 1.5x1.5x3mm, turbo cylinder head gaskets for 2.7 turbo
thanks, harold
Cheers
1969 Mercedes 280SL
Old 12-27-2004, 06:25 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Harold,
I wouldnt 'use the most thick once I can buy' as shim thickness needs to be selected to bring your deck heights to spec (you'll find this info in the book). The shims you posted are not typical....they appear to have been reused, installed incorrectly or the head studs possibly over torqued. In any case, not typical. You should be fine using the the correct thickness coppper shims, making sure your case and cylinder bases are flush and keeping the head studs torqued to spec.
BTW: Pistons do not apperar to be JE.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 12-27-2004, 09:27 PM
Jeff Alton's Avatar
Them there look like Mahle's. not JE.
www.turn3autosport.com
Old 12-27-2004, 10:29 PM
Author of "101 Projects"
Wayne 962's Avatar
There is no such thing as a 2.7 turbo. Is this that engine that you bought on eBay? Did you bolt a Turbo on it? With single plug and 11.5:1 compression? If yes, then it's no wonder the thing fell apart. Now I'm really confused.
Those cylinder base gaskets don't just get like that. This engine was beat to hell, potentially from detonation? Then perhaps the head studs pulled and the cylinders got loose and banged around the copper base gaskets. You just don't see that when tearing down an engine, unless the whole thing was imploding...
-Wayne
Old 12-27-2004, 11:56 PM
Hbrand
hbrand's Avatar
I hate turbo engines.
My thought was if the head is leaking I can work on the surefaces and install some kind of head gaskets. some members said the turbos had them - but that would be 3.o ltr and they would not work on my 2.8 ltr
I do not know how this engine was run by its former owner, all I want this engine to be is a fast long lasting stret engine.
thanks, harold
Cheers
1969 Mercedes 280SL
Old 12-28-2004, 06:41 AM
Super Moderator
cstreit's Avatar
WHat's with the cast looking surface on those pistons though, haven't seen that before on a Mahle piston.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-28-2004, 10:22 AM
Hbrand
hbrand's Avatar
More piston pictures. Mahle or J E??
Cheers
1969 Mercedes 280SL
Old 12-28-2004, 01:00 PM
Wayne 962's Avatar
thanks, harold
If this was the other motor you're talking about, it's not ever going to be a long-lasting engine, if you keep it in this config. 11.5:1 - nothing long-lasting about that, particularly with a magnesium case.
Take a look again at some of the chapters in the book, and that should help you decide what to do.
These pistons look forged to me - they look very much like Mahle RSR style pistons. They don't look like any JE pistons I've ever seen. The JE pistons I've seen are all machined across the top of the cylinder. These tops (minus the pockets) were forged.
-Wayne
Old 12-28-2004, 01:06 PM
Hbrand
hbrand's Avatar
Thanks wayne, first will determine the compression ratio I have and the zero in for about 10.
Will post nice pictures soon.
Thanks, harold
Cheers
1969 Mercedes 280SL
Old 12-28-2004, 02:15 PM
Wayne 962's Avatar
Thanks, harold
If this is that 2.7 engine, I would assume nothing and measure everything...
-Wayne
Old 12-28-2004, 02:20 PM
Banned
snowman's Avatar
Something banged the hell out of these copper spacers. Nothing std or within spec could cause this type of damage. And it is DAMAGE, big time. Do not put this thing back togather without finding out exactly what caused this.
Old 12-28-2004, 09:35 PM
Looks like 'fretting' caused by loose cylinders (pulled headstuds or undertorqued head nuts).
Old 12-29-2004, 10:04 PM
Banned
snowman's Avatar
rcwaldo stated the most likely cause.
Question- could this also be caused by pre ignition? In other words head studs pulled or stretched due to extreem pressure generated by pre ignition due to high compression ratio. See Waynes comments above.
In any case I would use only copper shims on rebuild. Thick copper shims are available if needed.
Long lasting street engine? CR on a Porsche is effectively about 1 point higher than on a water cooled engine according to Bruce Andersons book. Using premium gas with an ignition that includes knock detection would seem to limit the CR to 9.8:1. Otherwise without the knock detector to maybe 9.3 to one max. Thats for long lasting.
Your case almost certainly needs to be re decked as well.
Old 12-30-2004, 04:40 PM
