Question Flywheel Machining
Can the flywheel be machined and how much?
Scott S.
1981 911SC Targa
2004 Triumph 955i Daytona
2004 Dodge Dakota SRT
A whole bunch of OBD test cars
Old 01-01-2005, 08:59 AM
yes, generally. costs about $35. you need to tell the machinist to be sure it's not warped. he can tell easily once the grinder touches the flywheel. if a warped flywheel is resurfaced, you risk an imbalance problem, because more material will be removed from one side than the other. if you don't tell them, they just grind it, and you sometimes get a vibration that wasn't there before, requiring a re-do of the whole job.
206 637 4071
Old 01-01-2005, 09:41 AM
walt's Avatar
The wear limit is 8.5mm for an SC. Should be an indicator groove cut into it.
Walt
82SC 3.0
81SC 3.6
Old 01-01-2005, 09:58 AM
