H.G.P.'s Avatar
Page 135 last paragraph.."rotate the crankshaft"...how?
After tightening all the fasteners......"rotate the crankshaft"......What's the method here? Attach the pulley again?
Thanks.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 01-02-2005, 09:23 PM
Super Moderator
cstreit's Avatar
That's the easiest way. You don't need to final torque it, just use a rachet
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-02-2005, 09:44 PM
addictionMS's Avatar
omly guessing my book is downstairs, but I am guessing you have the rods in the case and the case halves together, if so, be aware the rods will hit the case and jamb up the crank, you need to fiddle with the rods to be sure they don't hang up.
It is the rod bolt nuts that catch on the inside of the case.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 01-02-2005, 09:46 PM
H.G.P.'s Avatar
OK. So I did that.....and the crank rotates freely, no-binding with my large torque wrench between 35-39 ft/lbs. (after tightening the pulley nut for rotation, when I go in the direction of the pulley nut "lefty-loosey", the nut will eventually loosen)
Does this sound right? Or do I need to change the torque on the case bolts to loosen or tighten the rotation?
Thanks for the advice.
1969 911 E Coupe
Old 01-02-2005, 10:52 PM
you should be able to rotate the crank by hand (on the pulley). 39ft/lb seems a lot to me.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 01-02-2005, 11:36 PM
H.G.P.'s Avatar
Yes, I see! I went around and checked all the torque values with another torque wrench, and found the oil cooler dome nuts to be a bit tight. Just a small difference, and now I can turn the crank pulley by hand, by one hand in fact. (It's firm though).
Thanks!
1969 911 E Coupe
Old 01-03-2005, 07:57 AM
Super Moderator
cstreit's Avatar
Firm is okay. It takes abit to overcome the "stickiness" of the assembly lube. I've found that it generally takes around 20 ft/lbs if done about right.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 01-03-2005, 10:58 AM
H.G.P.'s Avatar
After going crazy..... it stayed around 20 ft/lbs, but I could not move it by hand! Then after a very sllight change in the torque of cooler domes it finally came down to where I can move the pulley by hand thankfully.
(After compaining about passing through the homemade rod and chain supports, the case sat right down, fast enough and solid that I can't recall having a chance to see everything.....I know the pump seals went well, but it went so quick I wished I could have observed the #8 o-ring better.....but I was above the halves, ...but at least the #8 bearing looks good)
1969 911 E Coupe
Old 01-03-2005, 03:50 PM
H.G.P.'s Avatar
Originally posted by Wayne at Pelican Parts
Hmm, you can't check torque of a fastener if it's not turning - they will always read higher when they are static and not being tightened.
Hmm, my explanation is not clear?
-Wayne
I'm referring to amt. of resistance at the pulley. (Not the book explanations)
1969 911 E Coupe
Old 01-04-2005, 10:37 AM
H.G.P.'s Avatar
i.e. "freely" being highly subjective to this green-horn.
1969 911 E Coupe
Old 01-04-2005, 10:43 AM
