Page 135 last paragraph.."rotate the crankshaft"...how?
After tightening all the fasteners......"rotate the crankshaft"......What's the method here? Attach the pulley again?
Thanks.
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Super Moderator
That's the easiest way. You don't need to final torque it, just use a rachet
omly guessing my book is downstairs, but I am guessing you have the rods in the case and the case halves together, if so, be aware the rods will hit the case and jamb up the crank, you need to fiddle with the rods to be sure they don't hang up.
It is the rod bolt nuts that catch on the inside of the case. Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Does this sound right? Or do I need to change the torque on the case bolts to loosen or tighten the rotation? Thanks for the advice.
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche Last edited by H.G.P.; 01-02-2005 at 10:55 PM.. |
you should be able to rotate the crank by hand (on the pulley). 39ft/lb seems a lot to me.
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Thanks!
Super Moderator
Firm is okay. It takes abit to overcome the "stickiness" of the assembly lube. I've found that it generally takes around 20 ft/lbs if done about right.
(After compaining about passing through the homemade rod and chain supports, the case sat right down, fast enough and solid that I can't recall having a chance to see everything.....I know the pump seals went well, but it went so quick I wished I could have observed the #8 o-ring better.....but I was above the halves, ...but at least the #8 bearing looks good)
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche Last edited by H.G.P.; 01-03-2005 at 03:56 PM.. |
Author of "101 Projects"
Hmm, you can't check torque of a fastener if it's not turning - they will always read higher when they are static and not being tightened.
Hmm, my explanation is not clear? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
i.e. "freely" being highly subjective to this green-horn.
