Red face Broken Chain Guide - Mechanical Tensioners
Techies,
Upon disassembly I found the drivers side upper tesioner in pieces. Amazing that the motor still ran well. Lucky it didn't slip timing (I have only driven it home from where I bought it.) At least I know where the funny flapping sound was coming from.
Can I assume I have a bad tensioner on that side?
With all the talk of tensioner failures regardless of style I was thinking of going with mechanical tensioners. I don't mind a little periodic maintenance and the savings are big allowing expenditures in other areas, like chains & sprockets.
Can anyone correctly describe the setup & adjustment procedure for mechanical tensioners? Any brands to recommend for any reason?
All feedback is welcome.
Bill
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 01-03-2005, 05:12 AM
David's Avatar
Mechanical tensioner questions have come up several times over the years. A search should yeild lots of info.
Old 01-03-2005, 07:18 AM
Author of "101 Projects"
Wayne 962's Avatar
You mean solid tensioners? It's a great way to destroy your engine - read up on this in the Engine Rebuild Book.
I recommend the Carrera Chain Tensioners. Nowadays, they are the same price as the older spring-loaded ones...
-Wayne
Old 01-04-2005, 01:14 AM
I bought rebuild kits for my tensioners some time ago. I will likely go that way with the locks for back up.
I heard there is a difference between the OEM rebuild kits and the aftermarket. Any comment?
BTW, I now your book for procedures, great book.
Thanks,
Bill
Triplesn8s
Old 01-04-2005, 05:30 AM
