LinkBack | Thread Tools | Rate Thread |
Cases together, crank turns freely, anyway to peer inside (i.e) to verify/checklist?
Cases halves together, crank I can turn with one or two hands (firmly), and smooth.
Is there a verifying checklist that can be done at this stage, such as peering around inside through the cylinder holes to see that everything is seated well, seals, bearings, etc.,? (I did use a small mirror, and can see the large oil pump ring is well seated). Also, should I re-check all the torque values, etc., Anything else, as a check right after halves together? Thanks!
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Super Moderator
Well a boroscope would be perfect, but I doubt that you'd really be able to tell by looking that things are in order....
Rechecking the torque values is a good idea, but there isn't much else to do to check everything after it's all closed up.
What's the story behind the rebuild? stock 2.0? What kind of machine work was done to the case? These Mag cases are known to have all sorts of problems after they've been apart.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
2. Destroyed a (rare) OEM piston on #2. 3. Which also broke the piston skirt on #1. 4. Valve destroyed head #2. Fortunately did not drive ....coasted most of the way home where possible. 5. Priority = ORIGINALITY......or different car..........chose to keep originality 1969E (except for MFI change) 6. Choice of machine work........examination of intermediate layshaft OK vs. insert, ...measured ok, which so far seems to bear (no dropped bearings, steel studs in shape. etc.,) 7. Searched and found very hard to find rare Mahle E pistons. 8. Some priotiy problems solved: finding rare pistons, finding one rare in spec (in good shape) Biral cylinder., 9. Clean, clean, clean, and clean... 10.. messy first timer mating case halves i.e with sealer. 8. More details later hopefully............................
Author of "101 Projects"
Go light a candle at your local church?
![]() -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
